ᐅ How can I reinforce Bobby shelf boards that are sagging?
Created on: 11 Jan 2024 08:17
Labido
Labido
11 Jan 2024 08:17
Hello everyone, I have a problem with the shelves from Bobby sagging increasingly despite normal loading. The shelves are standard about 80 cm (31.5 inches) wide and made of relatively thin wood-based panels. I would like to know how I can stabilize or reinforce the individual shelves so they don’t sag any further. What methods are recommended here, are special supports or reinforcements advisable, or should I consider replacing the shelves? I look forward to your tips and experience!
nolan
11 Jan 2024 08:59
You can also screw a strip or a U-profile under the shelf board. This helps distribute the load more evenly and reduces sagging.
TEOZAR
11 Jan 2024 09:35
Hello and thank you for the detailed description! Sagging shelves usually occur when the load-bearing capacity is no longer sufficient. A common solution is to attach a wooden or metal strip underneath the shelf to reinforce it. A U-profile is especially effective because it rests on multiple points, distributing the load. It is important that the fastenings are secure and that the strips cover the entire length of the shelf. Additionally, you can check whether the shelf sides are stable enough, as their twisting can also contribute to sagging.
Tobias
11 Jan 2024 10:10
If you want to replace the shelves, I would recommend using thicker chipboard or MDF panels across the entire surface. These are stiffer and bend less.
nonpra
11 Jan 2024 11:02
You can also screw a strip across the underside of the shelf board to act as a central support beam. This helps to distribute the load more evenly and reduces sagging.
Jensson
11 Jan 2024 11:44
Hello, I would like to share a brief guide on how to reinforce Bobby shelf boards:
1. First, measure the shelf board (length, width, thickness).
2. Cut a wooden batten (for example, 20x40 mm (0.8x1.6 inches)) to the appropriate length.
3. Screw the batten centrally or along the front underside of the shelf board. Use at least 3 screws per batten to ensure good load distribution.
4. Alternatively, metal brackets or U-channels can be attached underneath the shelf board to provide additional support.
5. Check whether the shelf rails or side panels are still stable, and reinforce them if necessary.
A common mistake is using screws that are too short or not attaching the batten along its full length, which reduces the effectiveness. This method significantly reduces sagging.
