ᐅ What to do about squeaky hinges on a Billy bookshelf?
Created on: 16 Aug 2021 10:03
Merle
Merle
16 Aug 2021 10:03
I have noticed squeaking hinges on my Billy shelf and wanted to ask how to best fix this issue. The noises occur mainly when opening and closing the doors. I suspect it might be due to friction or lack of lubrication, but I am not sure if there could be another cause for this on an affordable piece of furniture like the Billy.
Has anyone experienced this problem and can offer practical advice on which materials and methods work best to make the hinges quiet again permanently? Is there anything specific to watch out for to avoid damaging the functionality or the material?
Thanks in advance for your help!
AMELIE
16 Aug 2021 10:45
Hello Merle,
Often, squeaking is caused by insufficient lubrication of the hinges. I recommend starting by cleaning the hinges, as dust and dirt can contribute to these noises. You can wipe them with a dry cloth or use a brush.
Afterwards, you can apply a suitable lubricant, such as a specialized silicone spray or a light machine oil. Please avoid using WD-40 or similar oils, as they tend to evaporate and do not provide long-lasting lubrication.
It is important not to apply too much, as the lubricant could get onto the shelf wood or the front, leaving stains.
If the squeaking persists after lubrication, the hinge screws might be loose. In that case, gently tightening them usually helps.
The Billy shelf unit is quite sturdy, so you don’t need to worry about any damage from oiling. If you have any further questions, feel free to ask. 🙂
roryvin
16 Aug 2021 11:29
Merle, a structured approach can help:
1. Remove the door from the cabinet to better access the hinge.
2. Visually inspect for dirt, rust, or damage.
3. Clean with a lint-free cloth.
4. Then apply a food-grade silicone spray or a Teflon spray, as these lubricants are non-sticky and do not attract dust.
5. Move the hinge thoroughly to distribute the lubricant.
6. Reattach the door and test its function.
Avoid mineral oil–based oils, as they cause dirt buildup and can harden over time.
If the squeaking persists, a slight deformation of the metal may be the cause, which might require replacing the hinges.
Leonardteo
16 Aug 2021 13:07
I agree with the previous recommendations and would like to emphasize the importance of using the right lubricant. After consulting several furniture professionals and gaining personal experience, I have learned that a grease based on lithium or MoS2, also known as multipurpose grease, is the most durable and effective.
This grease repels water and dust, which is definitely beneficial for frequently used hinges. However, it is a bit more difficult to apply, as it should be applied with a small brush or spatula.
For simple everyday applications, a good silicone spray is sufficient. It is important that the bearing points on the hinge are fully lubricated. Usually, just a few drops are enough. Afterward, move the hinge back and forth several times to distribute the grease.
semuneo
16 Aug 2021 15:44
Hello Merle,
I completely understand how annoying constant squeaking can be – I experienced it myself once. What helped me was using the right lubricant combined with a patient approach.
First, I manually moved the hinges slightly against their resting position – sometimes the mechanisms loosen a bit with some movement, which reduces the squeaking.
Then I sprayed silicone lubricant, and it worked almost like magic, especially after opening and closing the doors a few times.
Make sure not to apply the spray too close to the wood to avoid any stains. If you prefer a dry lubricant, I’ve also heard of Teflon powder, which is less messy but can be tricky to apply in practice.
I hope this helps you out. 🙂
cassandra
16 Aug 2021 16:18
Additional Information:
The squeaking in Billy shelf hinges usually results from metal-on-metal friction. This is often caused by missing or hardened lubrication, especially at the pivot points.
In addition to the silicone sprays already mentioned, I recommend regularly inspecting and maintaining the hinges to prevent the buildup of dust and dirt.
Another tip is to check the screws of the hinges and tighten them if necessary. If they are too loose, this causes extra movement and therefore noise.
If the hinges are damaged or bent, it is better to replace them. IKEA offers suitable replacement hinges for Billy furniture without any problems, and this is often cheaper than attempting repairs.
