ᐅ What should I do if the hinges on my IKEA PLATSA doors become loose?
Created on: 2 Feb 2020 09:23
solilisHello everyone, I have noticed that the doors on my IKEA Platsa cabinet are a bit loose at the hinges. However, all the fasteners seem to be properly installed, and I cannot find any obviously loose screws. My question is: What can I do if the IKEA Platsa door hinges are wobbly even though they are correctly mounted? What possible causes should I consider, how can I identify the problem, and what should I pay attention to when repairing or readjusting them? Are there any special recommendations for handling the hinges to improve their durability? I look forward to helpful tips and experiences! Thanks in advance.
First, check the screws on the hinge plate inside the cabinet. They often become slightly loose, even if it isn’t immediately visible. Tighten them fully. If the screws fit loosely, the plastic sleeves might be worn out; in that case, replacement is the only solution. Also, make sure the hinges are properly mounted and snapped into place.
SETHBLA schrieb:
First, check the screws on the hinge plate inside the cabinet. They often loosen slightly, even if it’s not immediately visible.This is a common issue seen with IKEA PLATSA cabinets. Besides tightening the screws, you should ensure that the mounting holes are not worn out. The plastic frame holding the screws can weaken over time, causing wobbling.
Additionally, lightly oiling the hinges can help ensure smooth opening and closing. For worn-out holes, repairs using special plastic repair kits or adhesive strips can be effective if you prefer not to replace the entire plate.
However, be careful not to overtighten the hinges to avoid further damage to the material.
The issue with loose PLATSA hinges can be addressed systematically in several steps:
- Step 1: Completely loosen the screws and then retighten them carefully, as screws often become slightly loose over time due to constant stress.
- Step 2: Visually inspect the drill holes and plastic inserts in the hinge area for any cracks or signs of wear.
- Step 3: For worn-out plastic bushings, inserting small washers or re-gluing with appropriate adhesives can temporarily improve stability.
- Step 4: Carefully adjust the hinges as needed until they fit without play. Avoid applying too much force to prevent damage to the material.
- Step 5: If none of these steps work, replacement parts are available from IKEA, known for their easy installation.
Regular maintenance and light lubrication of moving parts noticeably extend the lifespan.
solilis schrieb:
What can I do if IKEA PLATSA door hinges are loose, even though they are installed correctly?I completely understand how annoying a loose hinge can be – you usually trust the products, and then something like this happens. What helped me was making patient, small adjustments, even though it was frustrating at first. I learned that it’s not always necessary to replace the entire hinge right away.
I checked the screws one by one and gently tightened them, but never with too much force to avoid damaging the material. Additionally, for some hinges, I slightly cushioned the plastic inserts with thin adhesive tape, which helped reduce the play and improve the fit.
Patience and careful adjustments were key. I appreciate that the community shares solutions like this, because sometimes it’s the little details that aren’t obvious at first.
