Hello everyone, I recently assembled several IKEA Platsa cabinets in my apartment and unfortunately noticed some issues with the hinges on a few of the doors. Specifically, some hinges no longer close smoothly, while others seem a bit worn out or loose, causing the doors to be misaligned or even hang loosely again after a short time. My question is how to best deal with defective IKEA Platsa hinges? Are there proven repair methods, spare parts, or maybe adjustments I can make before ordering new hinges or seeking professional service? I would appreciate detailed tips, especially regarding whether there are differences between various hinge models within the Platsa range that I should be aware of. Thanks in advance!
If the screws hold in the hinge but the hinge is loose, often the only solution is to replace it. IKEA offers replacement hinges individually, so simply find the part number and reorder.
When installing, make sure the screws go into good, preferably undamaged drilled holes. Sometimes it helps to fill the hole slightly with wood filler or a toothpick so the screw has a better grip.
barle schrieb:
Sometimes it helps to fill the hole slightly with a wooden filler or toothpick to give the screw better grip.This is a very useful tip, thank you for the reminder. I would like to add that the stability of screw holes is one of the most common weak points with PLATSA, especially if the cabinets are moved frequently or slight shifts occur after several years.
For repairs, I often use hardwood strips that I fit and clamp in place before reinserting the screw. This provides a lasting stabilization of the hinge. A simple repair with wood glue plus a toothpick also works, but it is less durable.
If the hinges themselves are damaged, I recommend using only original replacement parts from IKEA, as PLATSA has specific fittings that often do not fit perfectly with third-party products.
Regarding repairs to PLATSA hinges, I would like to add that the door weight also plays a role depending on the door size. Especially if you have installed heavy doors, the hinge can be subjected to higher stress. In such cases, it may be worth considering switching to soft-close versions, which often feature a more robust spring mechanism.
If your doors are warping, it should also be checked whether the furniture is properly aligned and placed on a level floor, as otherwise the load will be unevenly distributed and hinges will wear out more quickly.
onron schrieb:
In some cases, it is worth switching to soft-close versions, which often have a more robust spring mechanism.This is a very good point, which I would like to expand on. In fact, the soft-close hinges from IKEA, especially those for PLATSA, are technically more advanced, offer greater comfort, and are generally more durable. However, they are also somewhat more expensive and require more space behind the door.
Whether a switch makes sense also depends on the installation, as some soft-close hinges are designed for different door thicknesses. I recommend checking compatibility with your PLATSA system before purchasing.
It would be helpful if you could specify which hinge models are installed and how the doors are used.
In general, soft-close models are definitely worthwhile for long-term use and higher loads.
kla69 schrieb:
Whether a replacement makes sense also depends on the installation, as some soft-close hinges are designed for different door thicknesses.I would like to highlight this point again. When retrofitting hinges, it is essential to pay attention to the correct dimensions. Especially with PLATSA, there are versions for 18mm (0.7 inches) and 22mm (0.9 inches) thick doors.
The position of the hinges is also crucial. If the hinges were installed incorrectly originally or if the holes have become worn out due to constant readjustment, this will repeatedly cause problems.
My advice is to always avoid excess and take time for precise adjustment. Replacing a damaged hinge completely is often the best solution, but only if the other conditions are right (undamaged hole pattern, correct door thickness, suitable hinge type).
