ᐅ How should I deal with faulty IKEA PLATSA hinges?
Created on: 24 Nov 2018 17:03
Dorus_me
Dorus_me
24 Nov 2018 17:03
Hello everyone, I recently assembled several IKEA Platsa cabinets in my apartment and unfortunately noticed some issues with the hinges on a few of the doors. Specifically, some hinges no longer close smoothly, while others seem a bit worn out or loose, causing the doors to be misaligned or even hang loosely again after a short time. My question is how to best deal with defective IKEA Platsa hinges? Are there proven repair methods, spare parts, or maybe adjustments I can make before ordering new hinges or seeking professional service? I would appreciate detailed tips, especially regarding whether there are differences between various hinge models within the Platsa range that I should be aware of. Thanks in advance!
Peone
24 Nov 2018 17:45
Hello Dorus_me, your issue with the IKEA PLATSA hinges sounds unfortunately quite common. Hinges can loosen over time, especially if the doors are frequently used or incorrectly adjusted. Generally, I would recommend first checking the screws on the hinges and tightening them if necessary. Sometimes, that alone is enough to realign the door properly.
If the hinge itself is damaged or worn out, individual hinges can usually be easily reordered from IKEA. In that case, you should check whether you have the standard hinge (e.g., 110° opening angle) or specialized versions (soft-close, etc.).
Another option is to completely remove the hinge to inspect whether dirt or foreign objects are affecting the closing mechanism. If the internal spring mechanism has failed, replacement is the only solution.
I hope this helps you as a first step!
kla69
24 Nov 2018 18:32
Hello Dorus_me,
I agree with Peone and would like to provide a more detailed explanation regarding the hinges, as PLATSA uses different types depending on the model and cabinet size. It is important that you first identify the exact type of hinge involved (e.g., 110° without soft close, soft-close, clip-on, etc.) since the mechanism and replacement parts vary.
Step by step, I recommend:
- Remove the hinges and check for external damage, especially cracks or bent metal.
- Test the spring tension of the mechanism; if it weakens, the hinge becomes unstable.
- Check the screws on the hinges, including those in the cabinet panel and door.
- First, adjust the three adjustment screws (top/bottom, side to side, front/back) to align the door precisely. This adjustment is often simpler than a full replacement.
- If you suspect the hole in the wood is worn out or damaged, I suggest drilling it out and inserting a wooden dowel to restore a firm hold.
A few questions from my side: How old are the cabinets, and are the doors heavily loaded? Weight often leads to premature wear of the hinges. Also, it would be helpful to know if the hinges catch or are rather loose.
With this information, it will be easier to determine whether a repair is worthwhile or if a replacement is the better option.
FELOTAU
24 Nov 2018 19:17
I understand your frustration, Dorus_me. Especially when you’ve just assembled cabinets, you naturally expect them to work smoothly, and when issues like these arise, it’s simply annoying.
I had a similar experience when I bought PLATSA cabinets some time ago. One hinge became unusually loose after just a few weeks, making it difficult to close the door. I then contacted IKEA customer service, and fortunately, ordering replacement hinge parts was straightforward.
What I found important was to stay patient and work carefully during installation, even though it can be frustrating. Sometimes these problems feel chaotic at first, but with the right approach, the issue can usually be resolved well.
If you decide to go the replacement parts route, I can only recommend checking all the cabinet hinges at the same time to avoid facing the same problem again shortly.
Rosaren
25 Nov 2018 07:53
Good morning,
I would like to add that when working with PLATSA hinges, it is helpful to have the right tools on hand: a screwdriver with a magnetic tip makes tightening the small screws much easier. Also, sometimes Allen keys are needed if special screws are used.
Another tip: after adjusting the hinges, test whether the doors close smoothly and evenly. If they catch or do not close fully, this may indicate incorrect adjustment or excessive play in the hinge.
If the hinge is mechanically damaged, replacement is unavoidable. Spare parts are relatively inexpensive through customer service. Those skilled in DIY can replace them within a few minutes.
Finally, I recommend checking the doors for possible causes of distortion, such as whether the cabinet itself is properly aligned. Sometimes the issue lies there rather than with the hinge.
Shawn38
25 Nov 2018 09:12
Rosaren schrieb:
Another tip: After adjusting the hinges, you should test whether the doors close evenly and smoothly.
That’s a crucial point you’re making. I once had a similar issue with IKEA furniture where I tightened the screws, but the doors still didn’t close properly because I neglected the fine adjustment. It really helps to take your time and adjust each screw step by step until the door fits perfectly.
Additionally, I’ve had good results applying a drop of silicone oil to the hinges. This often reduces squeaking and makes the movement smoother, without the need for constant retightening.
So: tighten the screws, check the adjustment, and if needed, lubricate the hinges – this usually solves most problems.
