ᐅ What should be considered when attaching IKEA Hemnes shelves to drywall (plasterboard) walls?
Created on: 13 May 2024 08:43
TelauHello everyone, I am planning to hang IKEA Hemnes shelves in my apartment, but the walls here are made of drywall (gypsum board). I am therefore interested in what exactly I should consider to securely and permanently mount the shelves.
In particular, I am concerned about the following points: How can the weight of the shelves be effectively transferred to the drywall? Which types of anchors are best suited? Do I need additional reinforcements, such as wooden beams behind the panel? And are there any practical tips or common pitfalls I should avoid?
I look forward to your experience and professional advice!
Nathanaelk13 May 2024 09:26Hello Telau, very good and precise question!
When dealing with drywall (gypsum board) walls, it is essential to adapt the fastening system to the lower load-bearing capacity of the gypsum boards. Hemnes shelves can get quite heavy, especially if you plan to fully load them later.
Basically, you can follow this approach:
- First, check if there is a substructure made of wooden or metal studs behind the drywall. Ideally, you can attach the shelves directly to these studs.
- Use a stud finder to locate the studs. The strongest fastening points are the studs themselves, since drywall alone can only carry limited loads.
- If direct fastening is not possible, use special hollow wall anchors or toggle anchors that are suitable for gypsum boards, for example metal toggle bolts or spring toggle anchors.
- Make sure the anchors are rated for the weight of the Hemnes shelves (general guideline: maximum 10–15 kg (22–33 lbs) per fastening point, so it's better to use multiple anchors).
- If possible, distribute the load via a substructure, such as a long wooden batten fastened over several anchors to spread the weight more effectively.
A few pitfalls to watch out for:
- Do not use regular plastic plugs, as they will not hold in drywall.
- Do not overload the shelves.
- For very heavy loads, definitely consider a supporting anchorage.
May I ask how wide the shelves are and how high you plan to load them? That will help with a more accurate assessment.
In addition to Nathanaelk’s explanations, the following points are critical for mounting IKEA Hemnes shelves on drywall (plasterboard) walls:
- Anchor type: For drywall, toggle anchors or metal expansion anchors are standard. These distribute the load behind the panel over a larger area.
- Number of fixing points: A minimum of 4 screws per shelf should be used, preferably more, to properly support the load.
- Load distribution: Load regulation should not rely solely on the screws but also on the construction. A support batten is recommended.
- Screw length: At least 35–50 mm (1.4–2 inches) must engage with the anchor threads to ensure secure hold.
Important: The total load of the shelves, including contents, must not exceed the maximum load capacity of the anchors; otherwise, the wall may be damaged.
Here is a brief guide for mounting IKEA Hemnes shelves on drywall (gypsum board) walls:
1. Preparation:
- Use a stud finder to check if there are studs behind the drywall at the desired height.
- Mark the positions of the studs.
2. Mounting on studs:
- Use suitable wood screws – at least 5 x 60 mm (5/32 x 2 3/8 inches).
- Pre-drill holes to avoid damaging the drywall.
3. Mounting on open wall areas:
- Use metal toggle bolts with screws of at least 5 mm (3/16 inch) diameter.
- Pay attention to the maximum load capacity of the toggle (usually about 20 kg (44 lbs)).
- Distribute the weight across as many anchors as possible.
4. Reinforcement:
- To increase load capacity, a horizontal wooden batten can be fastened to the studs, from which the shelf is then hung.
Common mistake: attaching shelves only at a few points on the drywall, which often leads to fastener failure and wall damage.
If you plan to fully load the shelves with heavy books, additional reinforcement with a wall-mounted wooden substructure is highly recommended.
1. Preparation:
4. Reinforcement:
Telau schrieb:
I’m looking forward to your experience and expert opinions!I had a similar project and can confirm that locating the studs behind the drywall is the most important step.
Nathanaelk schrieb:
Use a stud finder to locate the studs.It works really well—take your time to mark the exact position of the studs. Without these points, you risk compromising stability.
If you can’t find any studs, use metal toggle anchors and install at least four per shelf. The load should not be underestimated. I also recommend not overloading the shelf, especially if it is only attached to the drywall with anchors.
If possible, install a wooden batten at the height of the mounting points, secured with several anchors; this will help distribute the weight better.
Good luck with your project!
