ᐅ What common issues occur with Ikea Brimnes furniture when assembling it yourself?
Created on: 28 Jun 2024 18:37
kristoph34K
kristoph3428 Jun 2024 18:37Hello everyone, I would like to start a discussion on the topic: What specific problems are most common with Ikea Brimnes furniture when assembling it yourself (DIY)?
I am not referring to the general challenges of furniture assembly, but to particular issues that have been observed specifically with Brimnes furniture. For example, I have heard that screw holes are sometimes not perfectly aligned or that the plastic connectors used in Brimnes may not be very durable. Also, assembling the drawers and adjusting the doors are said to cause difficulties.
Does anyone have experience with what exactly to watch out for, which parts tend to be especially problematic, and how to best avoid these issues? Perhaps there are also tips on where to use additional tools or methods to prevent mistakes. I look forward to well-informed feedback!
Nathanaelk28 Jun 2024 19:12Hello kristoph34, your question is very well formulated and touches on several key points that I have also experienced with my Brimnes builds. Especially in DIY projects using the Brimnes program, there are multiple issues to be aware of to avoid frustration.
One issue is that the connectors, especially the so-called dowel connectors and Minifix fittings, are often manufactured with some imprecision. This shows up in screw holes not aligning perfectly or connectors feeling too loose or too tight when tightened. This can cause the furniture to wobble or loosen more quickly with use.
Another point is that the material used is mostly particleboard with a foil coating – which is generally acceptable, but if handled improperly, edges can easily fray or the surface can get scratched. These problems occur especially with longer drawer runners or back panels, where careful and precise work is required.
Regarding drawer assembly: The runners are functional, but you often need some patience because the drill holes are not always perfectly centered. This means you need to adjust the drawers until they run smoothly. Installing the doors can also be tricky because the hinges are delicate and require precise alignment; otherwise, they do not close properly.
Do you already have a specific Brimnes series or furniture type in mind? That could help me provide more targeted advice. How do you approach the assembly – do you strictly follow the instructions or make your own adjustments?
The most important thing with Brimnes is that the screw holes are often either too tight or too loose. Make sure to pre-drill the parts if necessary. The instructions are okay but not foolproof. Adjust the drawer slides afterwards, or they might jam. Do not over-tighten the plastic connectors, as they may break. These are the most common pitfalls.
Hello Kristoph34, I can confirm the experiences with Brimnes and would like to share a few basic principles that make the assembly much easier.
First, you should really take your time and check all screws and dowels before using them. Some of the drill holes are quite tight, as already mentioned, and lightly chamfering the edges with sandpaper can make a big difference, especially on the chipboard edges.
This is very important because the plastic used in Brimnes is not the most durable quality. The rule here is to work carefully and gently. A cordless screwdriver with a torque limiter is your friend.
This also matches my experience. Especially with drawers, it is useful to experiment with small adjustments after the initial assembly. This can prevent jamming.
Finally, I recommend assembling the furniture on a soft surface to avoid scratches on the laminate – and if in doubt, double-check all steps before fully tightening the screws.
I hope this helps you and everyone interested in this thread!
peovin schrieb:
Do not overtighten plastic connectors, or they will crack.
Nathanaelk schrieb:
The drawer slides are functional, but often require some patience, as the drill holes are not always perfectly centered.
