ᐅ What options do I have to protect Ikea BESTA surfaces from discoloration?
Created on: 21 May 2016 08:42
Je_anwar
Je_anwar
21 May 2016 08:42
I have a rather specific question about IKEA BESTÅ furniture, more precisely about the surfaces of the shelves and sideboards. I use these in my living room and have noticed that some surfaces show slight discoloration over time. Since I want to prevent the furniture from losing its appeal because of this, I am looking for ways to effectively protect the surfaces against such discoloration.
My main questions are:
- Are there recommended sealants or coatings that are compatible with the BESTÅ surfaces?
- Should special cleaning products be used, and if so, which ones?
- Does anyone have experience with protective films or similar products that are durable and do not peel off?
I would greatly appreciate detailed feedback, as I am unsure about the best way to preserve these delicate surfaces. Thank you in advance!
labau
21 May 2016 09:07
I have had good experiences with matte transparent protective films specifically designed for furniture. Otherwise, regular wiping with a damp cloth without using harsh cleaners is helpful. Sealing is rarely necessary with IKEA BESTÅ, as the surfaces are usually already coated.
PIN66
21 May 2016 10:33
Hello Je_anwar,
I would like to provide a more detailed response regarding your question about discoloration protection for IKEA BESTÅ surfaces, as this topic can be quite complex.
Most BESTÅ surfaces are made from melamine resin-coated particleboard. This type of surface is generally quite durable, but there is a risk of discoloration, especially with prolonged contact with stains from paint or food, exposure to UV light, and certain harsh cleaning agents.
To effectively protect your furniture, I recommend the following approach:
- First, always clean the surface thoroughly but gently, for example with a microfiber cloth and lukewarm water.
- Avoid aggressive chemical cleaners, as they could damage the coating and increase the likelihood of discoloration.
- If you want extra protection, special water-based varnishes or sealants approved for melamine-coated surfaces are suitable. These should be applied in thin layers. Acrylic or polyurethane varnishes are recommended, but you should test compatibility beforehand on an inconspicuous area.
- Protective films are also an option, especially for heavily used areas. Make sure to choose films that do not stick with adhesive but are mechanically fixed to avoid residue.
Please keep in mind that any additional protective coating may slightly alter the appearance of the surface, either in gloss level or texture.
Could you please describe more precisely where and how the discoloration has occurred? This will help provide more targeted advice. Is it caused by sunlight, kitchen odors, or perhaps by placing drinks or flower vases?
Je_anwar
22 May 2016 07:21
PIN66 schrieb:
Can you describe in more detail where and how the discolorations appeared?
Thank you for the detailed reply, PIN66.
I have mainly noticed the discolorations on the white surface of my BESTÅ sideboards. They are mostly found in areas where I frequently place potted plants or occasionally drinks. I suspect that moisture combined with minerals dissolved in the water affects the surfaces. Additionally, direct sunlight on the area for several weeks seems to worsen the discoloration.
I have not tried any special protective films yet, as I am concerned they might look unattractive and may not adhere well over time.
Perhaps a type of thin protective coating could be applied, provided it remains truly transparent and does not turn yellow. That would be ideal.
I would appreciate it if anyone could share specific products or experiences that help preserve surfaces with minimal effort.
edisondan
22 May 2016 10:45
To protect melamine-coated surfaces like those on IKEA BESTÅ, there are well-established methods that significantly increase durability.
- For cleaning, pH-neutral, mild detergents are recommended, as alkaline or acidic cleaners can damage the surface.
- For sealing, special water-based clear coats that offer UV protection are suitable. These clear coats should be applied thinly at least twice, allowing each layer to dry thoroughly in between.
- Protective films made of polyurethane or PVC are also appropriate but must be professionally installed to prevent wrinkles and air bubbles.
- Other options include treatments with nano-sealants that provide hydrophobic properties, thereby reducing stains and preventing discoloration.
Important: Test any protective treatment on an inconspicuous area first to rule out color changes.
Ultimately, the most effective way to prevent discoloration long-term is a combination of careful daily maintenance, avoiding direct liquid accumulation, and applying a protective film.
Janason
23 May 2016 08:55
Je_anwar schrieb:
I haven’t tried any special films yet because I’m worried they might look unattractive and not stick properly over time.
I understand that appearance is important to you. I have personally applied transparent protective films to BESTÅ floors, which are almost invisible and, after nearly a year, showed no discoloration or peeling. It is important that the film is specifically designed for furniture and does not use an aggressive adhesive layer.
What helped me:
- Make sure the furniture surface is very smooth before applying (remove dust, grease, etc.).
- Smooth out the protective film with a squeegee and watch out for air bubbles.
- Regularly check if the edges are lifting and, if necessary, re-adhere them.
If you want to try this, I can offer some recommendations for films or share experiences with materials that tend to be more matte or glossy.
