ᐅ What is the best way to paint or apply a vinyl wrap to IKEA PLATSA units?
Created on: 23 Apr 2016 17:07
PijonHello everyone,
I plan to either paint or apply a veneer to my IKEA Platsa shelving unit because I don’t like the standard surface and want a customized look. My main questions are: What is the best way to prepare Platsa to achieve a durable and even paint or veneer finish? Which types of paint or veneer are particularly suitable for the MDF or particleboard that Platsa is mostly made of? Are there any special tips for sanding, priming, and subsequent sealing or veneering to ensure the surface becomes robust and resistant to damage? I look forward to your experiences and recommendations – including advice on tools and the proper steps to follow.
To prepare your PLATSA shelf for painting or wrapping, the surface condition is crucial. The panels usually have a melamine-coated surface, which is difficult to paint directly. Therefore, I recommend the following steps:
- First, lightly sand the surface to remove the gloss. Avoid heavy sanding; use fine sandpaper with a grit of 220 to 320.
- Then, make sure to degrease the surface, for example with isopropanol.
- Use a primer designed specifically for plastic-like surfaces (e.g., an acrylic-based adhesion promoter) before painting.
- For painting, water-based acrylic or two-component paints intended for furniture are suitable.
When wrapping, it is important that the surface is clean and smooth. Usually, no further treatment is needed as long as the panel does not have significant unevenness. Pay attention to the air bubble properties of the wrap and use a squeegee for smooth application.
However, the most durable result comes from painting, as it seals the panel and makes it particularly resistant.
Enrico4 schrieb:
For preparing your PLATSA shelf for painting or foil wrapping, the surface condition is crucial.Exactly, that’s why I want to cover the topic more thoroughly and provide a kind of step-by-step guide:
1. Disassembly and Cleaning:
- Take apart the PLATSA components to easily access all sides for treatment.
- Clean the surfaces carefully, removing dust and grease.
2. Sanding:
- For melamine-coated surfaces, use fine sanding pads or sandpaper with a grit of 220–320.
- Sand lightly to slightly roughen the surface; the edges can be sanded a bit more, but avoid leaving coarse sanding marks.
3. Priming:
- Use an adhesion-promoting primer to improve water resistance.
- Make sure the primer is specifically suitable for plastics or coated furniture.
4. Painting:
- Apply an appropriate furniture paint, preferably water-based, to reduce odors and harmful substances.
- Apply several thin layers; lightly sand with very fine sandpaper between coats.
5. Sealing:
- Optionally, apply a clear coat sealer to protect the paint.
For Foil Wrapping:
- After thorough cleaning and slight sanding if needed, apply the self-adhesive foil from the center outward using a squeegee to avoid bubbles.
- Press the edges firmly and carefully finish with a heat gun if necessary.
Common Mistakes:
- Sanding too aggressively, causing an uneven surface.
- Insufficient degreasing.
- Applying paint layers that are too thick, leading to cracking or bubbling.
I hope this helps!
matthewon24 Apr 2016 07:51Enrico4 schrieb:
However, painting provides the most durable result because it seals the board particularly well.Really? I find that painting IKEA furniture is often quite a waste of time. The melamine surfaces are so thin that any scratch ends up damaging the paint anyway.
It is also said that laminating makes the furniture less "breathable" and can peel off, but if you use a good laminate, it still looks perfect after six months.
Personally, I would prefer laminate because it is quicker and far less work. Painting can easily become a drawn-out process, plus it takes days to dry. But of course, if durability is the priority, painting is the better choice. I would just recommend lowering your expectations for perfection beforehand.
I understand that painting or applying film to PLATSA can be a bit tricky, especially without professional equipment.
Honestly, that appeals to me—I’ve tried painting myself and ended up frustrated with the results.
So here’s my advice for anyone with little experience: definitely test paint or film on an inconspicuous part or panel before you start.
And don’t stress if things go wrong sometimes. Applying film is generally safer and quicker for a neat result, especially if you’re unsure about the techniques—even if the durability might not quite match that of paint.
I think this topic definitely deserves more open discussions about experiences and tips on how to best fix mistakes. So, if anyone has more practical experience, please share!
matthewon schrieb:
Personally, I would prefer using film because it’s faster and requires much less effort.
matthewon schrieb:
Personally, I would prefer using film because it is simply faster and requires much less work.I agree with that, but I would like to add some specific points to watch out for when applying film:
- Especially the edges of PLATSA are often sharp and not always perfectly smooth. Therefore, it doesn’t hurt to slightly round off the edges with some fine sandpaper to prevent the film from peeling later.
- Use film designed for furniture rather than walls, as it has greater flexibility and adhesive strength.
- Work patiently and, if possible, in a dust-free area.
- Avoid touching the surface with greasy or dirty hands.
If you decide to go with painting, make sure to check the compatibility of primer and paint. A poor combination can cause peeling later on.
Personally, I recommend a matte film for PLATSA, as it hides imperfections better than glossy paint.
