ᐅ What is important when customizing the Ikea PAX system to increase storage space?
Created on: 21 Jul 2023 09:37
ka-bu
ka-bu
21 Jul 2023 09:37
I am currently planning to extend my Ikea Pax wardrobe because I urgently need more storage space and want to make the most of the available area. I am particularly interested in what is generally important when expanding the storage to optimize capacity without causing issues later with functionality or stability.
For example, I wonder whether it is better to use only additional shelves and drawers or to work with system accessories such as pull-down closet rods, dividers, etc. Proper installation and weight distribution surely also play a role.
Has anyone had experience increasing storage space in the Pax system and can offer tips on what to pay special attention to during the extension? How can typical mistakes be avoided, and what has proven effective for you in practice?
I look forward to detailed responses, preferably including practical tips or personal experiences.
Lilau
21 Jul 2023 12:22
Hello ka-bu,
I completely understand how frustrating it can be when the available storage space is no longer enough. Your question is great, especially because people often try to save in the wrong place or just rigidly install the "standard solution."
What I have learned is that the most important thing is to really tailor the closet to your own needs. Not just adding more shelves, but also thinking carefully about what items you want to store.
ka-bu schrieb:
whether it is better to just add extra shelves and drawers, or to use system accessories like pull-down rods, dividers, etc.
Definitely go for the system accessories! They provide flexibility, especially for specific items like pants or shoes. At first, I only had simple shelves, but with these specialized solutions, I was really able to unlock the full potential.
Absolutely, heavy items should be stored at the bottom to avoid overloading or destabilizing the closet. And always check that the fittings are properly secured – otherwise, it can quickly become dangerous.
I hope this helps you a bit. It’s also important to take your time with planning! Good luck.
Joshbe
21 Jul 2023 14:53
Hello ka-bu,
regarding your question: "What is important when customizing the Ikea PAX system for more storage space?" there are several key points that I believe are essential:
- Planning: Measure your space precisely, including niches and height. Height is often underestimated, which can lead to wasted space.
- Modularity: Take advantage of the versatility of the PAX system by combining different modules, such as open shelves, drawers, and hanging rails.
- Weight capacity: Check the maximum load limits of shelves and fixings. Heavy items should be placed on sturdy lower shelves.
- Appropriate accessories: Shelves, drawer inserts, pull-down rails, and dividers not only help keep things organized but also significantly increase usable space.
- Installation: Ensure proper alignment and secure wall anchoring to prevent tipping hazards.
A best-practice tip: Always allow for some extra space, for example, 2-3cm (1 inch) more clearance between shelves for flexible use. And it’s better to buy more accessories than not enough, as retrofitting is usually inconvenient.
I follow these points in every customization and have had good experiences with this approach.
Surela
22 Jul 2023 10:06
Hello ka-bu,
I’ll respond to your question since fitting out a PAX wardrobe is an area where many things can go wrong if not done carefully.
First: The basic question you asked, whether more shelves and drawers will suffice or if system accessories should be used, is crucial. I definitely recommend a well-planned system of accessories tailored to your individual storage needs.
Regarding the approach:
- Measurement: Measure the exact internal dimensions of your PAX (width, depth, height). Especially with height, an inaccurate measurement is often used, which later leads to problems with items like clothes lifts.
- Needs analysis: Write down everything you want to store in the wardrobe (long or short hanging rods for clothing, drawers for accessories, boxes for small items). This prevents unnecessary accessory purchases.
- Stability & installation:
- Check the wall material for secure anchoring. PAX usually requires at least two screws at the top of the back panel.
- Pay attention to the maximum load capacity of each shelf (usually 25 kg (55 lbs), but it varies by type). Plan to store heavy items at the bottom.
- Accessory tips:
- Drawer inserts: Ideal for underwear, socks, to keep things organized.
- Clothes lift: Suitable when there is limited space. Be mindful of dimensions and adequate installation depth.
- Dividers: Prevent clothes or boxes from shifting and help create order.
- Interior doors or LED lighting can also increase comfort.
- Common mistakes:
- Not anchoring to the wall. This is a serious safety risk, especially with tall PAX units.
- Buying accessories without checking if they fit.
- Ignoring weight limits during installation.
I would be interested in how your room looks (e.g., ceiling height, any sloping) and whether you already have an idea of what you want to store in the wardrobe?
Then we can go into more detail.
