ᐅ How can the Ikea Pax wardrobe system be expanded with additional shelves?
Created on: 28 Dec 2024 08:37
LameelHello everyone,
I currently have a basic Ikea Pax wardrobe and would like to expand it with additional shelves to better organize the storage space. Since I already have some basic modules and shelves, I am particularly interested in how to extend the Pax frame structure with more shelves, dividers, or maybe small item organizers without compromising stability or appearance.
I am mainly looking for practical tips: Which extra parts really fit together, are there official extensions, or clever DIY solutions? How can installation errors that lead to instability be avoided? Are there specific maximum load capacities for additional shelf inserts?
It would also be helpful to know how to best utilize the existing interior space – for example, by showing types and dimensions of compatible shelves or possibly suitable third-party products.
Thank you in advance for your support and experiences!
Hello Lameel,
Your question addresses the core issue many people face with Pax: achieving flexibility and modularity while maintaining stability. For a proper extension, it is best to use the original shelves and dividers from the Ikea range, as these are specifically designed to fit the pre-drilled holes in the carcasses.
It is important to use the holes precisely to securely hang the shelves with dowels or plastic pins. Also, be careful not to exceed the maximum load capacity per shelf (usually around 15 kg (33 lbs) per shelf for Pax). If you want to install wider shelves, additional center supports, which Ikea also sells, are recommended to prevent sagging.
DIY solutions can make sense if you cut your own wood, but the standardized hole pattern should still be used – otherwise, the stability will suffer.
Perhaps you could provide some details about the dimensions and number of additional shelves if you already have a concrete plan? That would allow for more targeted advice.
Domau0 schrieb:
It is important to use the drill holes precisely to securely hang the shelves with dowels or plastic anchors.I agree with that: Using the original mounting systems is essential.
Additionally, it is worth considering that Ikea also offers extra interior fittings like pull-out drawers and inserts, which can be added. This often allows for more efficient use of storage space without necessarily installing additional shelves.
When extending with shelves yourself, parallel load distribution and following the assembly instructions are the best ways to prevent instability.
Very good question, Lameel.
To effectively and securely expand your Ikea Pax wardrobes with additional shelves, I recommend the following approach:
- First, check the current internal dimensions of your Pax frame, especially the width, depth, and height.
- Use Ikea’s own shelves designed for the Pax-specific hole pattern. These can be securely locked in place with the included pins.
- For heavy loads (for example, heavy shoes or accessories), it is advisable to use center supports or support strips, which Ikea offers as accessories.
- If you want more storage space at the top, you can install shelves closer together, or use drawer inserts or pull-out baskets.
- For a visually appealing solution—especially if you’re retrofitting—closed shelf doors or sliding doors are also useful to avoid a cluttered look.
When assembling, be sure to observe the load capacity (Ikea usually specifies 15–25 kg (33–55 lbs) per shelf). The drilling grid is set at 32 mm (1.26 inches) intervals—ideal for complementary planning.
What is your specific Pax model? (Dimensions, features) This would be important to provide precise recommendations.
To add to the points already well addressed, I would like to include the following:
The modularity of the Pax system allows for individually variable expansions – here is a detailed procedure on how to retrofit additional shelves:
1. Planning: First, create a measuring plan. Measure the height, width, and especially the number of existing drill holes in your carcass.
2. Selecting shelves: Purchase shelves that fit your carcass exactly. Also, pay attention to the depth – Pax offers different standard depths.
3. Assembly aids: Use original pins or dowels, as they are load-bearing and prevent slipping or misalignment.
4. Central supports and reinforcements: Always use these for wide shelves to distribute the load.
5. Interior fittings: Dividers or inserts can be placed directly into or hung inside the shelf compartments, depending on the internal dimensions.
It is also important to assemble correctly by precisely inserting the pins into the designated row of holes. For DIY systems, the 32-mm (1.26 inch) hole row is key.
A side question: Do you also want horizontal or vertical partitions? This significantly affects the planning.
