ᐅ What are your experiences with the stability of Pax sliding doors?
Created on: 12 Feb 2015 09:37
SebauHello everyone,
I am currently planning to install Pax sliding doors in my bedroom and wanted to ask about your experiences regarding the stability of these doors.
I am particularly interested in how durable the sliding doors are in everyday use, whether there are any issues with warping, jamming, or sticking, and if the track systems remain reliable over the long term.
Has anyone here gained insights into wear and tear or necessary adjustments after extended use?
The mechanical load in our household is average, but I value a long-lasting and stable solution.
Thanks in advance for your feedback!
Hello Sebau,
I have installed Pax sliding doors in my home for about two years now and can say from experience that the overall stability is solid, provided a few points are considered:
- Installation is crucial: The system only works perfectly if the doors and tracks are precisely aligned.
- I have not experienced any warping, although I have not subjected the doors to heavy loads or hung heavy objects on them.
- The running tracks are of good quality, and so far I have not needed major adjustments.
- However, I recommend periodically cleaning the tracks and rollers and possibly lubricating them to keep the movement smooth.
If you have any questions about specific installation details, I’m happy to help.
bareynaldo12 Feb 2015 14:04Sebau schrieb:
I am mainly interested in how durable the sliding doors are in everyday use, whether there are any problems with warping, jamming, or sticking, and if the track systems remain reliable over the long term.An interesting question, especially since the Pax brand is known for its affordable prices. But with budget systems, it often holds true that you get what you pay for.
In my opinion, the stability of Pax sliding doors is solid for standard use, but wear and tear become noticeable with frequent use.
In particular, the tracks and rollers can start to become loose over time, especially if they are not maintained regularly.
It’s also important to remember that the doors are made from relatively thin material, which limits their sturdiness compared to heavier, more solid alternatives.
For someone who wants true premium quality in the long run, Pax doors are more of a temporary solution or best suited for rooms with low traffic.
Anything else might be a bit overly optimistic.
bareynaldo schrieb:
You get what you pay for.That sums it up well.
In short: acceptable for occasional use, but for daily use, it's better to invest more.
Make sure to install the track properly and clean it regularly.
Interesting discussion so far.
I would like to add an analytical point: How exactly do you define 'stability'?
Is it mechanical strength (e.g., resistance to bending), or rather functionality (smooth operation and no faults), or the durability of mechanical components under continuous stress?
In my assessment, the stability of Pax doors is primarily a matter of installation and usage context.
Of course, material thickness and quality affect long-term durability, but often it is the interaction between the track, rollers, and door weight that makes the difference.
The structural integration into the furniture also greatly influences stability; loosely mounted doors can quickly become misaligned, even with high-quality hardware.
In this context: After about 3 years of daily use in my case, adjustments were necessary, but no major repairs. The rollers had worn out and needed replacing – spare parts are available and inexpensive.
Therefore, it might be sensible when making a purchase decision not to focus solely on the initial price but also to consider long-term maintenance costs.
Sebau schrieb:
Has anyone among you gained insights on wear or necessary adjustments after longer use?
