Hello everyone, I have a Pax wardrobe sliding door at home that keeps sticking. The door no longer slides smoothly but catches and gets stuck in certain spots. I have already checked for dirt or foreign objects in the track but didn’t find anything unusual. The tracks don’t appear to be bent either, but the mechanism overall feels a bit stiff. My question is: What exactly can I do to fix the sliding door from sticking? Are there simple repair steps or specific maintenance tips I should follow? It would also be helpful to know whether this problem is caused by general wear or if a component might be defective. I appreciate any advice!
PeoDaniel14 Aug 2024 10:13The issues with sagging sliding doors in Pax systems are often caused by debris in the tracks or worn-out rollers. It is important to first remove the doors and thoroughly clean the tracks. A damp cloth, possibly with a mild cleaning solution, works well for this. Afterwards, you can apply a suitable lubricant, such as a silicone-based spray, as these protect the mechanism and do not cause stickiness. Also, check the rollers at the bottom of the door—if they are broken or excessively worn, replacement is necessary. It is also advisable to inspect all screws and fasteners to ensure they are tight, as a loose door is more likely to get stuck.
To resolve a sagging sliding door issue with the Pax system, the following steps should be carried out systematically:
- Remove the door and check the tracks for damage, especially for any deformations or foreign objects.
- Clean the tracks thoroughly and then treat them with a silicone-based lubricant, as it repels dirt and prevents sticking.
- Inspect the rollers or running gear on the door for damage or deposits; replace them if necessary.
- Check whether the rollers are correctly adjusted, as incorrect positioning can cause heavy operation.
- Verify that the door is installed straight and plumb, since even slight misalignments can significantly affect sliding performance.
If these measures do not lead to improvement, there may be a technical defect in the closing or running system, requiring the replacement of components.
Paunon schrieb:
First, you should thoroughly clean the tracks; even small dust buildup can cause issues.That always sounds so simple, but honestly: If a door keeps sticking, it’s usually not just dust. IKEA tends to produce more budget-friendly quality, so you can’t expect much more. Often, the rollers are low quality and wear out faster than users realize. If you have to keep treating the problem with spray and tightening screws repeatedly, it’s ultimately just a temporary fix. In my opinion, replacing the roller or even the entire track is the only sustainable solution.
GALEO4 schrieb:
If you constantly have to treat the problem with spray and screws, in the end, it’s just a temporary fix.I would like to disagree with this. Considering the handling and age-related wear of components, maintenance with appropriate products and adjustments is not a temporary fix, but necessary upkeep. The tracks and rollers are wear parts in sliding doors, especially in Pax models with frequent use. Those who take preventive measures can often significantly extend the service life. Direct replacement only makes sense when there are visible damages or loss of function, not as a standard procedure.
