ᐅ What can I do if the screws for Ikea Hemnes furniture don’t fit?
Created on: 4 Feb 2016 08:23
Pimizar
Pimizar
4 Feb 2016 08:23
Hello everyone, I am facing a somewhat tricky issue with my current Hemnes wardrobe from Ikea: some of the supplied screws simply don’t fit into the designated drill holes or connection points. Specifically, there are different types and lengths, and for some screws, I get the impression that they are either too short, too long, or too large in diameter. The thread type is also not always clearly identifiable. My question to the community: What can I do if the Ikea Hemnes screws don’t fit? Are there any proven solutions to work around this issue or to find suitable alternative screws? I have already considered buying replacement screws at a hardware store, but I am uncertain about the exact specifications and don’t want to compromise on the material quality or the stability of the furniture. Looking forward to constructive tips and experiences!
keogla
4 Feb 2016 08:47
The best solution is usually to get a suitable screw with the same thread size and length from a hardware store screw set. IKEA screws often have special dimensions, but standard options can usually be found. Important: Always check the screw on the thread first.
V
valerie-tr
4 Feb 2016 09:12
Hello Pimizar,
first, it is important to understand exactly which screws do not fit and why. Ikea Hemnes furniture often includes several types of screws, such as pan-head screws, wood screws, and sometimes special connector fittings with machine screws. If a screw is too short, it can affect stability. If it is too long or has the wrong diameter, it can damage the material.
My suggestion for your approach:
- First, carefully check the holes using measuring tools (or compare with the screw packaging to see if they are, for example, M4 or M5).
- Make a table or list indicating which screw is intended for which part (according to the instructions or labeling).
- If screws are missing or do not fit: threads are usually metric standard (e.g., M4 x 40 mm (1.6 inches)).
- Look for screws with the exact same thread size and type at a hardware store.
- Pay attention to the material (galvanized, stainless steel), as this can be important depending on moisture or load.
- Do not force screws in – if the thread jams, the component could be damaged.
- Sometimes lightly reworking the hole (e.g., with a drill bit of the appropriate size) in wood can help.
I have a follow-up question: does the thread not engage at all, or are there physical fit problems, for example due to bent screws? Please describe whether you have already tried turning the screws or if they just fit in but do not hold.
Pimizar
4 Feb 2016 10:44
valerie-tr schrieb:
I have a follow-up question: Does the thread not work at all, or are there physical fit issues, for example due to bent screws?
Thank you for the detailed answer. The problem is that the thread on some screws clearly doesn’t match the drilled hole – I can’t screw them in at all. It feels like the screw diameter is too large or the size is incorrect. With other screws, they might be too short, so they don’t provide enough grip. I ruled out bent screws, as those are fine. I measured the thread dimensions of the most common screws, but I believe Ikea often uses special sizes here that I can’t find at the hardware store. Is there a more precise source for the dimensions of the Hemnes screws, or any recommendations on how to find suitable replacements without having to buy everything all over again?
RUBEN54
5 Feb 2016 07:56
Hello Pimizar,
I had a similar issue assembling a Hemnes shelf and can offer you some tips on how to proceed:
1. Sort screws: Lay out all screws by type and length, then compare them with the assembly instructions where they are usually labeled with numbers or letters.
2. Check thread size: Measure the diameter of the screws using a caliper or, if not available, a ruler, and compare them with standard sizes. IKEA typically uses standard threads like M4 or M5.
3. Find replacement screws: If you have a screw that doesn’t fit, you can purchase replacements with the same dimensions at a well-stocked hardware store or specialist supplier. The most important aspects to match are the length, thread size, and screw head type (e.g., pan head, flat head).
4. Inspect holes: Sometimes the drill holes in the wooden panels are slightly off or have burrs that prevent screws from turning in smoothly. You can carefully clean these with sandpaper or a countersink tool.
5. Avoid force: Turn screws slowly and if you encounter resistance, check whether you are using the correct part. Forcing screws can damage the mechanism.
Summary:
- Sort and measure
- Obtain replacement screws with identical dimensions
- Check and clean holes
If you have exact measurements, I can also help suggest common alternatives. Good luck!
deoke
5 Feb 2016 12:33
Hello Pimizar,
I would like to add to the points made by RUBEN54 and go into a bit more detail on the topic.
IKEA often uses special connectors and screws in the Hemnes series and similar lines, which have different thread types and lengths. If the fit is not correct, there can be several reasons:
- Manufacturing variations in the furniture itself
- Screws mixed up during assembly
- Confusion of screws during packaging
My advice:
- Definitely use a thread gauge or, if you don’t have one, at least a caliper to determine the screw diameter and thread pitch. This is the only way to be sure to get the right replacement.
- Pay attention to whether they are wood screws (self-tapping thread) or machine screws (metric thread), as the replacement parts differ significantly depending on this.
- Hemnes often also uses dowels, which may not grip properly if the wrong screws are used. Make sure these are intact and suitable.
- If you want to buy replacements, take one of the problematic screws with you to the retailer and, if possible, check the fit on site.
- If the screw is too thick, it could cause the wood to split. If it’s too thin, the hold will be unstable.
One more important note: a screw length that seems right on paper may not be optimal in practice. Check whether the screw penetrates sufficiently into the dowel or other material.
If you can provide specific measurements, I could also suggest suitable alternatives from the standard range.
