ᐅ Are there alternative fittings available for the IKEA Hemnes series?
Created on: 22 Apr 2022 09:12
ErikpiHello everyone,
I recently bought some Hemnes furniture from IKEA and noticed that the original fittings on some pieces seem a bit basic and not as durable as I would like. So, I’m wondering: Are there alternative fittings for IKEA Hemnes furniture that are, for example, more robust, longer-lasting, or visually more appealing? Ideally, they should be easy to install without much extra effort and at least match or exceed the original fittings in terms of functionality. I’m interested in hinges, handles, and other metal parts. Does anyone have experience or tips? Thanks in advance!
Hello Erikpi,
Regarding your question: Yes, there are definitely alternative fittings, even though IKEA mostly uses its own system. For the Hemnes series, you can mainly find replacement hinges from well-known manufacturers like Hettich or Blum – these often fit with minor adjustments. When it comes to handles, the selection is even larger, as you can basically use anything that matches the drill holes.
It is important to carefully measure the exact dimensions of the existing drill holes before purchasing, so you don’t buy the wrong fittings. Also, keep an eye on the load capacity of the hinges if you want to replace heavy doors. If you’re still unsure, I’m happy to provide more tips.
Sebastianm22 Apr 2022 10:03For Hemnes, standard furniture handles with a 64mm (2.5 inches) hole spacing usually fit without issues. For hinges, I recommend Blum, as they are durable and easy to obtain.
As an addition: IKEA’s Hemnes furniture typically uses standard 64mm (2.5 inches) hole spacing for handles, which makes replacement easier. Regarding hinges, they often use simple clip-on hinges without soft-close functionality.
Alternative hinges with soft-close features from manufacturers like Blum or Hettich can be installed after minimal adjustment of the drilling positions. It is recommended to check cabinet door thickness, drilling locations, and hinge arm type before purchase, as these can vary. Upgrading to higher-quality fittings noticeably improves durability and ease of use.
Using high-quality branded hardware usually pays off in the long run. For example, I switched to Blum hinges with soft-close on Hemnes cabinets, which significantly improved the user experience. Handles are a matter of personal taste, but make sure they do not affect the structural integrity and that the drill holes match exactly.
