ᐅ What alternatives to IKEA PLATSA are available for DIY projects?
Created on: 14 Jan 2024 10:23
sosupar
sosupar
14 Jan 2024 10:23
I am currently exploring storage systems in the DIY sector and came across the IKEA Platsa system. It seems quite interesting due to its modularity, adaptability, and relatively affordable prices. However, I am wondering about alternative systems or solutions that are equally suitable for DIY projects—especially if you prefer more flexibility, customizability, or even more sustainable materials.
I am therefore interested in: What alternatives to IKEA Platsa exist specifically for DIY projects that offer similar benefits such as modularity, easy expandability, and versatile components? Are there perhaps concepts that can be easily modified by yourself or that provide comparable functionality?
I would appreciate any tips, recommendations on brands, concepts, or even independent DIY ideas that could be considered serious alternatives. Thanks in advance!
Mufato
14 Jan 2024 11:07
In short: Take a look at the modular system from Hettich. It’s very sturdy and flexible.
For more heavy-duty options, the STEELCASE modular system is also worth considering.
If you prefer a DIY approach, using basic MDF boards and rails from a hardware store is a good way to work modularly.
Lucien
14 Jan 2024 13:46
IKEA PLATSA stands out primarily due to its simplicity and modular design. As alternatives in the DIY sector, modular shelving systems and plug-in systems with easily combinable components are especially relevant. Here is an overview of notable options:
- Kallax from IKEA itself as a simple, modular shelving unit with many plug-in options
- Hardware store plug-in systems made of metal or wood, often combined with customizable elements
- Plug-in room systems made of plastic (e.g., SONGMICS) – less durable but flexible
- Traditional wooden frames with variable inserts that can be self-built and expanded
Key factors are the use of durable materials and the ability to flexibly combine various sizes or units. In the DIY sector, the advantage is clear: you can implement custom measurements precisely. However, IKEA offers the benefit of good integration with doors and drawers. Some DIY systems do not offer this easily.
Nathanaelk
15 Jan 2024 09:02
I would like to add to the discussion with a more detailed overview, especially regarding material choices and planning in the DIY sector as an alternative to the IKEA PLATSA system.
1. Materials:
- Plywood panels are very popular due to their stability and appearance – they offer better durability than particleboard or fiberboard.
- Solid wood is a genuine alternative when sustainable and long-lasting material is desired, though it is more expensive and requires more effort to work with.
- Metal frames (e.g., made from angle iron or profiles) can be welded or screwed by DIY enthusiasts; they are particularly sturdy but require appropriate equipment.
2. Planning and Modularity:
For flexible systems, it is advisable to use a grid dimension, such as a 32mm (1.26 inches) or 96mm (3.78 inches) grid, similar to professional furniture standards, to facilitate easier component replacement later.
3. Fasteners and Accessories:
- Connectors (e.g., cam locks, dowels) help keep modules easy to disassemble.
- Drawer systems and doors often work best in DIY setups when combined with standard rails (Blum, Hettich).
4. Sustainability Aspect:
The DIY approach often enables a more conscious use of materials, such as FSC-certified woods or low-emission finishes.
Lastly, a question to sosupar: What is more important to you – the flexibility and modularity like PLATSA offers, or rather the material quality? And is the focus primarily on pure shelving/storage systems, or are other types of furniture planned as well?
KIN42
15 Jan 2024 10:36
Nathanaelk schrieb:
What matters more to you – flexibility and modularity like with PLATSA, or rather the quality of the materials?
This is a key question. I would add that in DIY projects, the combination of modular construction and the option for easy expansion or replacement is often the priority.
A good alternative is so-called modular systems from the craftsmanship sector, for example systems with pre-cut grooves for dowels and biscuits. These offer stability, are easily adjustable, and do not require special fittings.
If you feel comfortable working with wood joints and precise cutting, this would be a very flexible DIY option.
Trate47
16 Jan 2024 07:54
Good morning everyone!
I always find it fascinating how many creative DIY solutions can rival PLATSA.
One system I like to recommend is the shelving system from OEHLEN, which stands out especially for its variety of modules and mix of materials (wood, metal, glass). Of course, it costs a bit more, but the appeal lies in the freedom to combine components individually – something DIY enthusiasts really appreciate.
Also: since you value material quality and modularity, how about modular systems that use tool-free plug-in connections, like those used in exhibition stand construction? Super convenient for people who prefer assembling by plugging parts together instead of screwing.
A small heads-up: if you plan to do a lot of remodeling, material costs and time can multiply quickly – but hey, the journey is almost the goal, right?
