I mounted a Kallax shelf on the wall, but unfortunately the wall bracket has repeatedly broken after some time – despite careful installation according to the instructions and using the provided screws. The shelf is well loaded with books and decorations, but not overloaded beyond what it should handle. Now I am looking for more stable or alternative wall mounting solutions that are safer and can hold the shelf without it eventually falling or the bracket failing.
What experiences have you had with wall mounts for Kallax? Are there other mounting methods or even alternative installation systems I could try? It is important to me that the solution does not require significant damage to the wall (so not too many anchor holes, etc.) and, of course, is reliably stable.
I appreciate any tips!
Hello Sonba, I can understand well that this is frustrating and worrying for you when the bracket keeps breaking. It is also disappointing when you put in effort and the result still doesn’t hold up.
I think your idea to reinforce the wood where the bracket is attached is very good. That should relieve some of the stress on the material. If you also slightly support the shelf against the wall from below with an angle bracket, it would further reduce the force on the bracket and might prevent it from breaking.
Having multiple safety measures is better so you can feel confident when using it. All the best with the implementation!
Hey everyone! Great discussion here :-)
I just want to jump in quickly and say: I recently solved this exact problem by mounting a rail (an aluminum rail with multiple holes, e.g., a T-slot rail) on the wall instead of using the original brackets, and then hanging the back of the Kallax shelf unit on it with matching hooks. It feels really stable, and you can even slide the shelf if you want.
Of course, this means some work measuring and adjusting, but I think it’s worth the effort. This way, the shelf basically becomes a wall-mounted cabinet version, which looks pretty cool and is safe. No more breakage!
If anyone wants to know more, I’m happy to share more details.
vinus schrieb:
Shelf almost like the wall cabinet version, which looks pretty cool and is secureThat sounds really interesting! I’ve never considered a rail like that before. Is there a specific model name or supplier where you got the material? How exactly did you connect the shelf to the rail—what kind of hooks did you use?
I would really appreciate it if you could share more details, as this seems to be a truly elegant solution.
Sure, happy to help!
The rail I use is a so-called "T-slot aluminum rail," available at hardware stores or online. It has holes at regular intervals, allowing flexible use of screws and hooks. For the connection, I bought special "hooks for T-slot rails" (available in different types, for example, for screwing or hooking).
The shelf has a few thin wooden strips on the back, to which I attached the hooks. These strips ensure that the shelf is securely mounted and does not hang directly on the frame.
The installation was somewhat complex, but the result is very sturdy. And you can easily unhook the shelf if needed.
If anyone is interested, I can also put together a small sketch or step-by-step description :-)
