I mounted a Kallax shelf on the wall, but unfortunately the wall bracket has repeatedly broken after some time – despite careful installation according to the instructions and using the provided screws. The shelf is well loaded with books and decorations, but not overloaded beyond what it should handle. Now I am looking for more stable or alternative wall mounting solutions that are safer and can hold the shelf without it eventually falling or the bracket failing.
What experiences have you had with wall mounts for Kallax? Are there other mounting methods or even alternative installation systems I could try? It is important to me that the solution does not require significant damage to the wall (so not too many anchor holes, etc.) and, of course, is reliably stable.
I appreciate any tips!
Hello Sonba,
I can definitely help you with this. First of all, it’s important to know whether you have mounted the Kallax using the original mounting brackets or if you have tried other types of fittings. The original mounting set is designed for light to medium loads – books and decorations can quickly cause the screws to pull out of the anchors, especially in drywall.
For a more secure installation, the following points are crucial:
1. Wall type: concrete, brick, drywall? Standard plastic anchors usually are not sufficient for drywall.
2. Quality of anchors: heavy-duty anchors or metal expansion anchors are almost essential here.
3. Number of fixing points: more is better, as the load is distributed more evenly.
If you have drywall or a partition wall, a sensible approach would be to use hollow wall anchors or even special toggle anchors (e.g. metal spring toggle bolts) before mounting. These spread behind the wall, enabling significantly higher load capacity.
Alternatively, you can fix a wooden panel horizontally to the wall and lean and secure your Kallax on it – this way the load is distributed much better across the wall surface.
Please describe your wall structure and the current mounting setup in more detail so I can assist you more precisely.
Hey Sonba,
I also had the problem with my Kallax shelves where the fasteners were a bit weak – it’s really frustrating when a little one knocks something down! 🙂
What worked well for me was a combination of heavy-duty wall plugs (sometimes called metal anchors) and an additional mounting rail that I screwed to the wall behind the shelf. This basically provides a second level of support for the shelf. I also used some cable ties to secure it – sounds odd, but it actually helps.
And yes, more attachment points, meaning screws, are always better. It’s better to have a few extra holes than a broken shelf. Hope this helps you already!
Hello Sonba,
I would like to share a structured tip on how to make your wall mounting more secure:
1. Check the wall: masonry or drywall. For drywall, do not attach only to the wall surface, but secure to a backing wooden stud or frame – use a small stud finder or impact drill for this.
2. Anchors: For masonry use high-quality heavy-duty anchors such as Fischer UX or Fischer SXR. For drywall, use hollow wall anchors (metal toggle bolts) or foam fixing systems.
3. Load distribution: Avoid using just one or two screws; it’s better to use multiple fixing points – for example, attach a horizontal batten behind the shelf with several screws.
4. Load limitation: If possible, don’t fully load the shelf; distribute the weight evenly.
5. Alternative mounting: If you don’t want to drill holes, you can fix T-slot rails to the wall and hang shelf parts from them – though this is somewhat more complex to implement.
I hope this helps. I’m happy to provide more detailed advice if you can describe exactly what kind of wall you have.
TEBILO schrieb:
If you have a drywall or plasterboard wall, a practical approach would be to use hollow wall anchors or even special toggle bolts (e.g., metal spring toggle anchors) before mountingI agree to some extent, but I wonder if such solutions simply avoid the fundamental problem instead of solving it. If the wall itself is too weak, it might be better to consider different positioning or alternative furniture such as freestanding shelves.
Also, the suggestion that a wooden panel helps makes sense, but how is it attached? It must not be forgotten that it also requires secure anchors.
Does anyone know better strategies that tackle the problem at its root? I think the topic of anchor types and load distribution deserves deeper analysis.
