ᐅ Why do screws keep coming loose from my Billy bookshelf?
Created on: 7 Oct 2020 08:24
Lulemo
I have a somewhat specific question that has been on my mind for a while: Why do screws keep coming loose from my Ikea Billy shelf, even though I assembled it correctly and used the screws provided for it?
I made sure not to damage the drill holes and connection points, and there are no obvious signs of damage to the wood or screws. Still, the screws loosen over time, especially on the shelves, even with normal use.
I suspect it might be related to the material quality or the type of screws, or maybe the shelf isn’t designed to handle the load properly. What are your experiences or tips for solving this problem permanently?
Thanks in advance for your advice!
GEKAU51
7 Oct 2020 10:01
Dopoki schrieb:
Chipboard material flexes.
I think the Billy-style shelf is only a temporary solution anyway and actually of poor quality. It’s no surprise that screws come loose. Who would expect something like that to be permanently stable?
It’s better to invest right away in solid wood or metal shelving instead of getting frustrated over loose screws. Cheaply made, cheaply processed – you’ll notice it sooner or later.
plopra
7 Oct 2020 10:15
If screws fall out of the Billy shelf, it is often because the screw is too short or the wrong type.
Try longer screws or ones with a coarser thread. These hold better in particleboard.
JAFUHAU
8 Oct 2020 12:42
I completely understand how frustrating it can be when a piece of furniture keeps falling apart.
Maybe it helps to assemble the shelf on a flat surface and avoid overloading it – this provides stability and prevents the screws from being pushed out due to uneven weight distribution.
Sometimes you feel alone with these small problems, but here you can see that many people experience the same. 🙂
COLEBAR
9 Oct 2020 07:32
plopra schrieb:
longer screws or those with a coarser thread
Exactly. I always make sure to use the next size up; it costs almost nothing and provides a lot more hold.
LOJOPAR
10 Oct 2020 15:53
For those who want to know the details:
Particleboard consists of crushed wood pressed together with a binder. The material absorbs moisture and can lose its holding strength when screws are repeatedly inserted and removed, as the wood fibers are damaged. This results in a stripped or worn thread.
Using metal or hard plastic threaded inserts usually creates a much more stable connection. This investment is especially worthwhile if the shelf is going to be reassembled frequently.
Additionally, make sure that heavy loads are not always hanging in the same spot – try to distribute the weight as evenly as possible.
This helps to extend the lifespan of the shelf and the screw connection.
BeAndrea
10 Oct 2020 18:29
LOJOPAR schrieb:
Particleboard consists of shredded wood pressed together with a binder. The material absorbs moisture and can lose its holding strength if screws are repeatedly inserted and removed.
That is exactly the crucial point. Additionally, it is advisable not to drive screws in too deep—a certain distance from the edge of the board prevents the material from splitting under the screw head.
If you have some DIY skills, using small metal brackets can significantly improve stability.
Be patient and take enough time for assembly—this really pays off in the end! 🙂
