ᐅ Looking for Tips on Magnetic Handles for KALLAX Units!
Created on: 26 Nov 2022 13:27
Ennopra61
Hello everyone, I am currently dealing with a fairly specific issue that might also interest some of you: I am looking for effective tips and tricks on how to attach magnetic handles to the IKEA KALLAX shelving unit.
The handles should be not only visually appealing but also practical, without damaging the unit or requiring major modifications. It is especially important to me to know which type of magnets work best, how to securely fix them, and if there are any particular handling recommendations to ensure durability.
I am also interested if anyone has experience with alternative fastening methods besides screws and adhesives, possibly even magnetic solutions that can be removed without leaving any residue.
I look forward to your ideas, experiences, and of course any critical feedback. Thanks in advance!
Danial
27 Nov 2022 13:37
A brief analytical addition:
DULIS schrieb:
It’s best to attach a thin steel plate on the back; then neodymium magnets work great.
In my opinion, this is the key issue with magnetic handles on the KALLAX. Without a magnetically conductive surface (such as steel), no magnet will really hold.
The challenge remains to install the steel plate in a way that is as invisible as possible or visually matches the shelf unit.
I would suggest recessing such plates flush into the back, possibly coating them with a suitable paint or using double-sided tape to avoid screws. This optimizes both appearance and durability.
Has anyone tried this yet? What was the effort involved, and how does it hold up in everyday use?
Repar
27 Nov 2022 15:04
You can also use strong magnetic strips, which can be applied with adhesive tape. They are more flexible and can be attached over larger surfaces.
However, be careful: the adhesive strength varies on wood-based materials – always degrease the surface thoroughly beforehand.
JAMESONB41
28 Nov 2022 08:50
To sum up the topic:
Steel plates glued on, combined with neodymium magnets and epoxy adhesive, offer the most reliable solution.
The idea of using adhesive pads works sometimes, but the durability greatly depends on the usage.
Gofoman
28 Nov 2022 11:33
I would like to revisit the topic of durability:
Tinaneo schrieb:
I find the following question much more important: What is the distance between the handle and the shelving wall?
That’s exactly where the problem lies. With magnets, every additional millimeter of distance causes a dramatic decrease in holding force. Temperature can also cause surprises, as neodymium magnets lose their magnetism when exposed to excessive heat.
Therefore, it’s important to understand that magnetic handles always represent a compromise between appearance, functionality, and durability. Anyone choosing this solution should not expect it to handle extreme stress.
My advice: It’s better to install small magnetic catches as additional support or opt for a hybrid solution using both screws and magnets, so you have something solid to hold onto and don’t have to constantly fix the handles.
