I have a specific question about cleaning Malm shelving surfaces, especially those made of wood or veneer from IKEA. I’m particularly interested in which cleaning products you recommend to thoroughly clean the surface without causing discoloration or damage. It would also be great if someone could share tips on how to prevent or remove scratches, as the shelves in my home are used quite heavily.
I would also like to know if you follow any special care routines—such as regular oiling or using certain types of cloths—and what should definitely be avoided, for example harsh cleaners or abrasive materials.
Looking forward to your experiences and advice. Thanks in advance!
Hello funamo,
regarding your question about the best way to clean Malm surfaces, I can provide some detailed advice. Malm surfaces are usually made of MDF with a foil coating or veneered wood surfaces, which are quite sensitive to moisture and harsh substances.
First, you should avoid using sharp or abrasive cleaners, as these can dull or damage the surface. A pH-neutral all-purpose cleaner is ideal. I recommend using a microfiber cloth, which is gentle on the surface and absorbs dust well.
When cleaning, apply the cleaner only to the cloth, not directly onto the surface, to prevent damage from liquid seeping under the foil.
Scratches can often be partially concealed with special wood polish or furniture wax, but deeper scratches are usually permanent. In those cases, careful sanding and possibly refinishing with lacquer or oil may help, although this can change the original surface.
For maintenance, regular dusting and occasional wiping with a slightly damp cloth is sufficient. Oiling is not suitable for foil surfaces; it is better suited for solid wood.
May I ask if your Malm surface has a foil finish or real wood veneer? This might affect the cleaning method slightly.
INGRID34 schrieb:
I strictly avoid aggressive cleaners. This is a very important point. Too many people try to clean the surface using products intended more for tiles or kitchen countertops, which causes long-term damage.
I would like to agree with Dilen here and add a few points, as the details often make the difference when it comes to Malm shelves.
I work a lot with wooden furniture and have noticed that Malm surfaces are usually laminated – which is an advantage because they are fairly resistant to water stains, but a disadvantage because natural wood care products like oil should not be used.
My approach for Malm shelves:
1. Remove dust with a dry, soft microfiber cloth.
2. For dirt, clean with a slightly damp cloth and a mild, pH-neutral cleaner. I often use diluted dish soap for this.
3. Wring out the cloth well after wiping to avoid leaving any moisture behind.
4. Never use abrasive cleaners or harsh chemicals – even citric acid can damage the surface.
If there are scratches, sometimes a furniture touch-up marker in a matching color or repair wax (available specifically for laminated surfaces) can help. Important: always test any treatment on an inconspicuous area first.
One small tip to avoid scratches: use coasters with felt pads underneath and avoid placing heavy objects directly on the surface that could get moved around.
How do you handle this? Have you ever tried furniture touch-up markers? I’m also interested in how you deal with more stubborn stains.
Dilen schrieb:
May I ask if your Malm shelf has a foil surface or real wood veneer?Thank you for the detailed answer, Dilen! My Malm shelf is probably more of a foil coating, as Palenar also suspected. The surface feels quite smooth, no real wood texture.
Palenar schrieb:
Use coasters with felt pads underneath and avoid placing heavy objects directly on it that could slide.That is very valuable advice, as I recently got a small scratch from a heavy flower pot that slipped.
Do you have any recommendations for mild cleaners that are safe to use on foil surfaces? I’m often unsure which household products are suitable. Maybe some experiences with specific brands?
And what about cleaning frequency? I want the surface to look good for a long time without over-maintaining it.
