ᐅ Safe Electrical Installation in the Shower
Created on: 5 Dec 2022 11:20
ateliersiegel
ateliersiegel5 Dec 2022 11:20
.... I love brightness and would like to have a light fixture above the shower.
It is clear and sensible that electricity and water must be kept separate.
My plan is to cover the electrical components – including the LED bulb – with an acrylic glass enclosure, so that even if someone directs the shower spray upwards, there would reliably be no contact.
Does anyone know where I can find the regulations, or how I can find out exactly what is actually prohibited?
andimann5 Dec 2022 11:54
Hi, only low-voltage LEDs (I believe they are 12V) are allowed in the shower area. Anything else would be too risky for me as well....
Andreas
ateliersiegel5 Dec 2022 12:48
andimann schrieb:
Anything else would really be too risky for me....
I understand.
In the shower area, okay.
If there is a wall in between, it would be safe and likely allowed.
My plexiglass enclosure would be just as waterproof as a wall. Personally, I wouldn’t consider it a safety issue. However, I’m concerned about things like insurance and regulations, so I would prefer to have a source where it is clearly stated in writing.
i_b_n_a_n5 Dec 2022 12:56
You are a tradesperson, okay. And if you are confident that you are doing everything correctly, go ahead. But: mistakes in this area can potentially be fatal! Spend the money here and have a certified electrician do the work, taking full responsibility with their signature. I think the small cost is worth it for the high level of safety.
Pacmansh
5 Dec 2022 14:16
Anything over 225cm (7 feet 5 inches) is within protection zone 3 and relatively straightforward, right? I would still use a luminaire with an IP rating of X4/5 there. I don’t think a plexiglass enclosure is essential, but it would further reduce the risk.
ateliersiegel5 Dec 2022 15:06
Throughout the entire house, we have installed GU10 LED bulbs almost everywhere.
I would like to keep it that way.
Therefore, an IP X4/5 rated fixture is not really an option.
To me, this is mainly a matter of the solidity of the enclosure surrounding the electrical components. You can even install lights in bathtubs. So it should be possible to do the same above a shower area.
However, I might reconsider my plan and use LED light strips designed for outdoor use instead (12 or 24 watts).
