ᐅ Retrofitting and Precisely Adjusting Soft-Close Mechanisms on Ikea Metod Cabinet Doors
Created on: 19 Dec 2021 18:37
FranciscoF
Francisco19 Dec 2021 18:37Hello everyone,
I want to upgrade my Ikea Metod kitchen fronts, which currently don’t have a soft-close function, by installing compatible soft-close hinges. I’m especially interested in how to add the soft-close feature without fully removing the fronts and what to keep in mind when precisely adjusting them so the doors don’t close too slowly or too quickly and are properly aligned.
Specifically: Which hinges are suitable for this upgrade? Do I need special adapters? How do I correctly adjust the soft-close damping, especially regarding the closing angle and pressure settings? I would also like to know if there are any tips for adjusting the doors in three dimensions so that the overall appearance looks like new fronts.
Thanks in advance for your advice and experiences!
Francisco schrieb:
Which hinges are suitable as an upgrade? Do I need special adapters? How do I precisely adjust the soft-close damping, especially regarding the closing angle and pressure strength settings?For retrofitting, I recommend the original Ikea Metod soft-close hinges. Adapters are usually not necessary, as these hinges fit directly into the existing drill holes. For adjustment, there is typically a screw on the hinge that lets you fine-tune the damping. You can align the doors using three screws: up/down, side to side, and in/out relative to the cabinet. Simply loosen the screws, adjust the door, and then tighten the screws again.
Hello Francisco,
I understand your question well, as upgrading to soft-close hinges is definitely worthwhile, especially if you use the doors frequently. In addition to what NIKA61 mentioned, I would like to add the following:
- Ikea’s soft-close hinges for Metod cabinets are designed to fit the existing drill holes – usually, no adapter is needed.
- The damping mechanism is built into a small insert in the hinge that controls the closing speed. Some models have a small adjustment screw, while others have a fixed damping, in which case you usually adjust the closing angle instead.
- The door can be adjusted in three ways:
- Vertically: to align the door with the others in height.
- Horizontally (side to side): to set the gap between the cabinet box and adjacent doors.
- Depth (in/out): for a flush door fit and even front alignment.
- After installation, you should open and close the door several times to allow the damping to settle in.
- If the doors close too slowly, it can help to reduce the damping slightly or adjust the screw.
I hope this helps. If you have specific issues with the adjustment, feel free to provide more details!
Francisco schrieb:
I want to upgrade my Ikea Metod kitchen fronts, which currently don’t have a soft-close feature, by installing compatible soft-close hinges.Here is a simple step-by-step tutorial on how I did it:
- First, remove the old hinges. This is easiest if the door is taken off. If you want to avoid that, you can try retrofitting the soft-close mechanism directly, but often it’s simpler to replace the entire hinge.
- For hinges, you can buy the matching Ikea Metod soft-close hinges; they fit plug and play.
- The fronts are attached using the existing drill holes—no adapters needed.
- Door adjustment is done via three adjustment screws on the hinge:
- Up/Down: To align the door relative to the kitchen cabinet.
- Side to side: To adjust the gap between the door and the cabinet frame.
- Depth: To make the door flush with adjacent fronts.
- For fine-tuning the soft-close function, there is usually a small screw to adjust the cushioning intensity. If present, turn it carefully, test the closing action, and adjust gradually.
- Tip: Make sure the doors don’t slam against the cabinet frames when closing but close smoothly and quietly.
- If the doors still don’t close properly after adjusting, check that the hinges are properly seated.
The result should improve noticeably—the doors close more easily and damage less by banging or slamming.
If you have any questions, I’m happy to help.
