ᐅ Replacing BILLY Shelf Doors – Where to Find Affordable Alternatives?
Created on: 20 Feb 2018 08:43
Pirapeo
Pirapeo
20 Feb 2018 08:43
Hello everyone, I plan to replace the doors on my Billy shelf because the old ones are damaged and no longer look good. Unfortunately, the original Billy doors are quite expensive, so I’m wondering if anyone here knows of affordable alternatives that fit well or are similarly easy to install?
It’s important to me that the doors are sturdy and look reasonably high quality; they don’t necessarily have to be originals. Maybe someone knows of stores, hardware centers, or online retailers that offer budget-friendly doors suitable for Billy shelves?
Any tips on DIY solutions or building your own doors would also be helpful if anyone has experience with that. Thanks in advance for your advice!
susar
20 Feb 2018 09:22
Pirapeo schrieb:
Unfortunately, the original BILLY doors are quite expensive, and I’m wondering if anyone here knows of affordable alternatives
Hey, I totally get that! The original doors are really pricey, but I once saw some simple MDF doors at a hardware store called Bauhaus that fit almost perfectly. Just take the measurements, have them cut to size, and attach with hinges—the result was surprisingly great and, best of all, very affordable!
You can also paint the doors in any color. I did it myself, and it was really fun 🙂 This way, you not only save money but can also customize the doors—really clever!
Joe52
20 Feb 2018 10:15
susar schrieb:
simply measure the dimensions, have them cut, and then attach with hinges
That’s a really great tip, thanks for sharing! I also think it’s important not to get discouraged if the original parts are too expensive. There are often practical ways to make it work.
I’m also curious if anyone has experience with doors made from lightweight wood or particle board, and whether they are truly durable enough for everyday use. Sometimes you worry that such a budget alternative might break easily.
RonJarrett
20 Feb 2018 11:38
Regarding Pirapeo’s question about affordable alternatives for BILLY bookshelf doors:
I have researched and found that many users refer to so-called "Ikea hack" websites, where you can find instructions and sources for cost-effective replacement doors.
The most common method is to have doors cut to the standard sizes of 40 x 106 cm (16 x 42 inches) or 60 x 106 cm (24 x 42 inches) at local timber or hardware stores using simple materials such as MDF or particleboard. Suitable hinges compatible with the original BILLY fittings are then used. The material can be painted with a matte finish or laminated to resemble the original.
In online shops like Hornbach or Toom, you can often find inexpensive raw boards for under 20 euros per door.
Quality differences should be considered: Cheap particleboard may warp when exposed to moisture. For durability, it is better to choose MDF or coated boards.
O
onquinn
20 Feb 2018 13:42
RonJarrett schrieb:
Choose MDF or laminated boards
Exactly, MDF is stable and easy to work with. Just ask around at the hardware store; often they will cut the boards for you free of charge.
Gino38
21 Feb 2018 07:55
Just one addition: If you plan to paint the doors yourself, make sure to use high-quality paint—preferably acrylic or alkyd paint, as these are durable and resistant to moisture.
Otherwise, there are websites like "IKEA Hackers" where you can often find instructions for affordable reproductions or custom modifications.
You should also not underestimate the hinges—they need to fit perfectly; otherwise, the door won’t close properly or may stick. It’s best to buy original IKEA hinges and use them with the custom-made door.
