ᐅ PLATSA from IKEA: Which types of tools are essential for assembly?
Created on: 22 Feb 2019 08:37
aimeekauHello everyone, I am planning to assemble the PLATSA system from IKEA and would like to clarify in advance which types of tools are truly essential for a smooth and secure assembly. I understand that IKEA furniture is generally well-designed and often requires only simple tools, with an Allen key often included. However, I want to be on the safe side to avoid running into missing tools later or possibly damaging the furniture due to incorrect handling.
I am therefore interested in detailed advice based on your experience—whether it is recommended to have special screwdrivers, drills, rubber mallets, or similar tools in addition to the supplied ones. Are there particular types of tools that are especially important for assembling PLATSA to properly tighten screws and securely fix the rails or connections? Or is the included equipment completely sufficient? Furthermore, I would like to know if using certain tools can make the assembly process faster and more reliable overall.
It would be great if you could share your experiences and tips so I can start well-prepared and put the system together solidly and neatly.
Johnathon22 Feb 2019 10:12Hello Aimeekau,
First of all, I think it’s great that you are giving careful thought to the tools needed for assembling PLATSA. Generally, IKEA provides the basic tools for PLATSA, usually a hex key (Allen wrench) for the screws – which is sufficient for many of the connections. However, depending on the number of modules you plan to assemble and the surface and conditions on site, it can be useful to have additional tools available.
- Hex key / Allen wrench: The included tool is often small and only suitable for basic screwing. Having a set of hex keys with different sizes allows you to work more comfortably and with better torque.
- Screwdriver: Most screws are crosshead (Phillips), so a good Phillips screwdriver is practical, especially for any fine adjustments to fittings.
- Rubber mallet: Extremely helpful for tapping in wall plugs (anchors) and for slight alignment adjustments of the modules. The rubber head prevents damage to decorative surfaces.
- Cordless drill/screwdriver: Use with caution. If you are experienced, a cordless drill with torque control can speed up assembly, but it’s best to finish tightening screws by hand with a hex key to avoid over-tightening or stripping.
- Spirit level: To make sure everything is perfectly level and modules don’t rock.
If you plan to join several modules or fix shelves to the wall, you should also have a drill and appropriate wall plugs (anchors) and screws ready.
Some tips to avoid issues:
- Pay attention when screwing in, always start with light pressure to protect the material.
- The size and positioning of the screws are clearly specified in the assembly instructions; follow these exactly.
I’d be interested to know how many PLATSA modules you plan to build and whether the system will be completely freestanding or fixed to the wall? This can influence your choice of tools.
KarTristan23 Feb 2019 09:48I agree with Johnathon on many points and would like to add that the tools needed for assembling the PLATSA unit are quite straightforward overall, but for an efficient and safe assembly, the following equipment is worthwhile:
- A complete set of hex keys (Allen wrenches), since the ones included are often too small and awkward to use.
- A high-quality Phillips screwdriver to prevent slipping and damaging the screws.
- A rubber mallet, which makes it easy to insert dowels without causing damage.
The correct torque when fastening is actually very important, as PLATSA uses different types of screws for the back panel, rails, and connectors.
I completely agree. Overtightening can cause the particleboard to split or the connection to become too tight. Having a good feel for handling the tools is extremely helpful.
I also found a spirit level very useful for alignment. Especially when connecting multiple units, it helps prevent a crooked outcome. For wall mounting, a drill and appropriate wall plugs (anchors) are essential.
If you have any questions about tool selection, particularly regarding the advantages of certain hex key sizes, I’m happy to help.
Johnathon schrieb:
Cordless drill driver: I recommend being cautious here. If you are experienced, a cordless drill with adjustable torque can speed up the assembly
As a complement, I would like to add that precise and well-fitting tools are especially important for assembling PLATSA, to avoid damaging the delicate surfaces and edges of the modules.
- The supplied Allen key is designed for basic use only; for less tiring work, high-quality hex keys or appropriately sized bits for cordless drills with adjustable torque control are recommended.
- A small Phillips head screwdriver with a thin blade makes it easier to tighten smaller screws in tight spaces.
- A rubber mallet is highly advisable, particularly for tapping the base supports or back panels into place, where a gentle touch is necessary.
- A spirit level ensures exact alignment and prevents gaps at the joints, which could later cause instability.
Absolutely, manual skill plays a crucial role in the outcome and should not be underestimated. After all, the PLATSA system consists of chipboard modules with decorative foil, which can be easily damaged if the wrong tools are used or too much force is applied.
Summary: With an Allen key, Phillips screwdriver, rubber mallet, and spirit level, you are already well equipped. Use a cordless drill only if you have sufficient experience and it has torque limitation. If you plan to attach the modules to the wall, don’t forget a drill and wall plugs.
If you want to know more precisely which screw types and sizes are used with PLATSA, I can also provide that information.
KarTristan schrieb:
Manual skill really helps here.
