ᐅ Master bathroom layout
Created on: 7 Nov 2017 16:02
R.Hotzenplotz
Hi!
What do you think about this master bathroom layout?
We didn’t really want the shower to be so hidden since we plan to outfit it in a high-quality and stylish way. It would be nice if it could be more visible, not just for showering. But during the plumbing planning, we were advised to keep it like this (because of the water pipes).
What’s your opinion? Or does anyone have an idea on how to create more visibility into the shower?
The two washbasins are marked incorrectly. We will only use one washbasin (1m wide (39 inches)). Our idea is to move the bathtub to where the washbasins are currently shown and place the washbasin on the right wall instead. We want the bathtub to have a prominent spot in the room instead of being “in the corner” when we bathe.
Currently planned components:
Toilet: Duravit Happy D.2 extended version, 25500900001
Washbasin: Villeroy & Boch Venticello 1000x500mm (39x20 inches), 4104ALR1
Bathtub: still considering either Villeroy & Boch Squaro Edge 12 Combipool Invisible (UIP190SQE2B1V96) or a Kaldewei Conoduo, both 190x90cm (75x35 inches) (235200010001)
Shower:
Villeroy & Boch shower tray Futurion or Squaro Infinity
Hansgrohe Axor ShowerSolutions thermostat module Select 530 / 90 for 3 outlets, 18356000
Hansgrohe Axor Shower Solutions 350 1jet overhead shower with ceiling connection, chrome, 26035000
Keuco meTime_spa waterfall showerhead, 59982010000
Hansgrohe Axor Starck 1jet handheld shower, chrome, 10531000
Looking forward to your feedback!
Grundriss eines Badezimmers: Badewanne rechts, zwei Waschbecken in der Mitte und Toilette links.
R.Hotzenplotz
21 May 2018 22:27
Why use a shower tray when you can tile the shower floor? Probably no one does it as a custom solution.
The plumber advises against it. A shower tray is considered more reliable in terms of waterproofing.
21 May 2018 22:44
R.Hotzenplotz schrieb:
The plumber advises against it. A shower tray is definitely safer in terms of waterproofing.
Ah, yes!
That’s always how we do it, isn’t it?
Müllerin
21 May 2018 23:22
I would use tiles and invest the money saved in something else nice...
chand1986
22 May 2018 06:50
In hundreds of thousands of public showers (sports halls, swimming pools, etc.), tiling has been done in roughly the same way since ancient times. Just saying...
matte
22 May 2018 07:32
Don’t let anyone convince you otherwise...
Tiles are not the waterproofing layer anyway. A proper waterproofing system is applied underneath first.
Search on YouTube for “Waterproofing – Shower and Bathroom permanently watertight”
That explains it clearly. So, if you prefer a tiled shower and the shower tray is only there because the plumber wants it that way, I’d suggest changing the plumber rather than the tiled shower.
If you want the shower tray simply because you prefer it, go ahead.
R.Hotzenplotz
22 May 2018 07:38
I actually find the visual contrast created by using a shower tray quite nice. But tiles are also okay in my opinion, as long as there are no disadvantages. Tiles are an option before I have to order a custom-made piece at an exorbitant cost or end up with a shower tray that I don't like.
I just need to check whether you can simply use the regular tiles that are also in the bathroom. I’m not sure how slip-resistant they are.
