ᐅ Clever and Space-Saving Storage Solutions for Small Kitchens Using Ikea METOD Cabinets
Created on: 21 Nov 2021 19:37
V
VINCENZO3V
VINCENZO321 Nov 2021 19:37I am currently trying to optimize storage space in a very small kitchen using the Ikea METOD system in the most efficient and space-saving way. My kitchen measures only 2.5 x 3 meters (8.2 x 9.8 feet), and I want to create as much usable space as possible without increasing the feeling of crampedness. I am considering various organization options, the modular adaptability, and smart solutions like pull-outs, corner cabinets, or wall cabinets. Are there any specific recommendations on how to use storage space with METOD furniture really efficiently, especially when space is limited? Which combinations of cabinets, internal fittings, or accessories have proven effective? And what should I definitely pay attention to in order not only to gain storage but also to ensure quick accessibility and a comfortable work surface?
I understand very well that in small kitchens like yours, measuring 2.5 x 3 m (8.2 x 9.8 ft), you want to make the most of every centimeter of storage space. The METOD system is actually well suited for this since it is modular and allows for many different interior fittings.
I recommend the following:
- Plan cabinets with drawers instead of traditional doors, as this greatly improves accessibility.
- Use interior pull-outs in taller wall cabinets so you can easily reach items stored there as well.
- Corner cabinets with a Magic Corner may take up some floor space but provide a lot of storage capacity.
- Add open shelves or wall cabinets above the countertop to create space for frequently used accessories.
- Also pay attention to the working height when planning: the countertop should be ergonomically suitable to enable efficient and comfortable work.
If you like, you can share measurements or sketches, and then we can give more specific advice for your kitchen.
A structured approach to optimizing your METOD system in small kitchens is essential. Here is a brief guide:
- Planning: Measure the space precisely, including windows, doors, and rear connections.
- Cabinet types: Base cabinets with pull-out drawers save more space than deep shelves. A depth of 60 cm (24 inches) is standard; consider wider units if you need even more storage.
- Corner solutions: Magic Corner or swivel pull-outs are better than fixed shelves, as they make more efficient use of corners and offer better visibility.
- Interior organization: Use inserts such as cutlery trays, plate holders, and shallow boxes to maximize the volume.
- Use vertical space: Wall cabinets above the countertop extending to the ceiling, with adjustable shelves, allow for flexible storage.
- Accessories: LED lighting inside cabinets and under wall cabinets improves visibility and helps make the most of the storage space.
It is also important to plan enough workspace and avoid blocking kitchen pathways. Storage should always remain easily accessible.
Julien schrieb:
Corner cabinets with magic corners do take up some floor space but offer a lot of storage capacity.That is generally true, but you should also consider that magic corner systems are often less durable due to their mechanics and can become a weak point over time. If you plan to store heavy items, solid drawers might be more long-lasting.
Additionally, it’s worth thinking about whether work efficiency can be improved with other solutions, such as a well-designed layout featuring drawers of various sizes with soft-close mechanisms.
Also ask yourself whether the desire for maximum storage might come at the expense of freedom of movement. Finding the right balance is key.
FRANCISCOP23 Nov 2021 13:45To optimize with METOD in small kitchens, I recommend paying close attention to the cabinet depth. Standard depths of 60cm (24 inches) can feel cramped in small spaces. There are reduced depth modules (e.g. 40cm (16 inches)) that work especially well for wall cabinets, offering more space without significantly sacrificing storage capacity.
Another point: use interior fittings like vertical plate holders on the cabinet side panels. This keeps baking sheets or cutting boards organized.
A combination of open shelves and closed cabinets also creates clarity and feels less overwhelming.
My tip: use the free Ikea planning software before purchase to try out different layouts.
