ᐅ Optimizing the Floor Plan of a 180 sqm Single-Family House with a Gable Roof and No Basement
Created on: 18 Oct 2020 11:54
RicoNeuber
we are currently in the middle of planning our single-family house described here. We would be very grateful if you could share your suggestions and feedback. We truly appreciate every tip and comment.
Plot size: 967 sqm (10,404 sq ft)
Slope: rises evenly by 1 m (3.3 ft) from north to south, with a gradual decline of about 1 m (3.3 ft) from east to west
Site coverage ratio: None
Floor area ratio: None
Building envelope, building line, and boundary: Northernmost exterior wall may deviate up to 6 m (20 ft) from the alignment line of the neighboring development to the east.
Boundary development: Yes, boundary wall/shared wall with neighbor allowed
Number of parking spaces: At least 2
Number of storeys: No restrictions
Roof shape: Gable roof with pitch over 35°
Orientation: Driveway from Street 2 (north)
Maximum heights/limits: Ridge height 11 m (36 ft)
Other requirements:
- No floor-to-ceiling windows on the facade facing the street on the upper floor.
Owners’ Requirements
Architectural style, roof shape, building type: Gable roof with 42° pitch (north/south orientation), knee wall 1.25 m (4 ft)
Basement, number of floors: No basement, 1.5 storeys
Number of occupants, ages: 4 persons (2 adults, 2 children)
Room requirements ground floor, upper floor:
- Ground floor: Kitchen, dining room, living room, office, pantry, utility room, WC with shower
- Upper floor: 2 children’s rooms, master bedroom with walk-in closet, bathroom, (office from ground floor could be moved to upper floor)
Office use: family use or home office? Home office
Open kitchen, kitchen island: Open-plan living and dining area; no kitchen island
Number of dining seats: 6
Fireplace: Masonry heater
Music/sound wall: No
Balcony, roof terrace: Ground floor terrace facing southwest, no upper floor balcony
Garage, carport: 1 garage attached to the house; 2 additional garages already at the edge of the plot (northwest boundary)
Who did the planning:
- Do-it-Yourself
- Ground floor: layout and room sizes; orientation of rooms
- Upper floor: orientation of the master bedroom facing north
- Bathrooms stacked (lower cost?!)
What do you dislike? Why?
- Space utilization on the upper floor; children’s rooms might be too large?!
- Layout of pantry / utility room – concern that pantry may be warmed through the utility room
Preferred heating technology: Air-to-water heat pump + masonry heater / ground-source heat pump with horizontal collector + masonry heater
If you had to give up, which details/extensions could you do without: Third gable on the upper floor facing south
Which cannot be omitted: Master bedroom in the northeast, utility room and pantry in the northeast
Why did the design turn out as it is now?
- Consideration of experiences from two home builders
- A mixture of many examples from various magazines...
What is the most important/fundamental question about the floor plan, summarized in 130 characters?
- How can we optimize the upper floor layout while keeping the ground floor room arrangement the same?
- Do you have further ideas regarding the type and position of the staircase?
Site plan of a building plot with blue building mass and setback and alignment lines between two streets.
Rural scene: stone wall, houses with red tiled roofs, garden beds and trees in front of a green area.
Floor plan of a house: kitchen, living area, office, bathroom, pantry, utility room, hallway, and staircase.
Upper floor plan with two children’s rooms, master bedroom, walk-in closet, bathroom, and staircase.
Two-storey beige house with gray gable roof and side garage on green lawn.
Two-storey beige house with gray tiled gable roof on green plot (3D rendering).
Nice-Nofret
18 Oct 2020 22:52
The pantry should be at least 130cm (51 inches) wide; it will have exactly the same temperature as the surrounding rooms, no matter how well you insulate it – what would it cool down? The building envelope in new constructions is much too well insulated.
In its planned form, the room is therefore pointless.
Ysop***
19 Oct 2020 06:34
I would also appreciate the furnishing. This way, it’s easier to see where there is too little or too much space. I would choose the entrance to the master area through the walk-in closet.
Pinky030119 Oct 2020 06:43
Are the floor plans oriented to true north?
The pantry won’t be practical as it is. As mentioned before, all rooms in the house will have roughly the same temperature. In this layout, it will be difficult to furnish or use it effectively.
Have you already thought about the kitchen?
RicoNeuber
19 Oct 2020 08:50
Thank you all for your feedback. Today we will draft the furniture and fixtures layout and make it available to you here.
Best regards!
RomeoZwo19 Oct 2020 16:18
To avoid making the upper floor too complex, I would suggest experimenting with the following layout ...
Floor plan of a house with bedroom, dressing room, bathroom, child 1 and child 2 around central staircase
Access to the bedroom would then be through the dressing room. You might need to adjust the staircase position a bit and/or modify the dimensions of the bay window. And as @11ant says, check afterwards how it works on the ground floor (it should still be possible).
What is behind the wonderful stone wall at your neighbors’ place? A cloister garden?
RicoNeuber
19 Oct 2020 22:13
Hello everyone, as promised, we have redrawn the floor plans here with our planned furnishings. I have marked the south orientation with an arrow.
A few additional details about the floor plans:
1) Ground floor:
- While drawing, we noticed that the pantry was too narrow (thank you for your feedback)
- The staircase is planned as a closed staircase -> Therefore, we think the hallway does not need to be too large, as a closed staircase reduces the space. However, we are not entirely sure about this
- Kitchen: the induction cooktop will be positioned facing the dining table, so you don’t have to look at a wall while cooking. We also hope this improves interaction with children/guests. An exhaust vent leading outside through the exterior wall is, of course, planned. We welcome any other suggestions you may have.
- The dryer, washing machine, and freezer will be located in the utility room.
2) Upper floor
- Due to the orientation, we prefer not to move the bedroom to the south
- The positions of the furnishings in the children’s rooms are not yet final. We only wanted to mark them to see how much free space remains in the rooms.
- We are considering recessing the dormer window on the north side flush with the exterior wall. This could create a sort of seating area. What do you think?
- We are not yet fully satisfied with the bathroom layout. However, this was initially just to estimate how much space we need.
Please feel free to share any further suggestions and ideas. We would be very happy
@RomeoZwo You’re right, that is a monastery park.
Floor plan of a house with hallway, stairs, living room (sofa), dining room, stove, TV cabinet.
Floor plan of an apartment with bed, shower, bathtub, and cabinets; dimensions indicated.
