ᐅ New KALLAX shelf unit has a color defect – should I complain or accept it?
Created on: 24 Feb 2023 10:37
nohau61
nohau61
24 Feb 2023 10:37
I recently ordered a new KALLAX shelving unit from IKEA, and upon unpacking, I noticed that the surface shows significant color variations in several spots. These are small patches and streaks that don’t seem repairable. The color differences look like production defects, with uneven and partly faded areas.
Since this is a new piece of furniture, I’m wondering if it makes sense to file a complaint about the color issue or if I should just accept it.
Has anyone had experience with KALLAX and similar color variations? How flexible is IKEA in these cases? Is the complaint process lengthy or complicated?
I actually want to keep the furniture because I need it urgently, but the color spots really affect the overall appearance. On the other hand, it’s not exactly cheap, and I’m curious how the manufacturer usually handles such quality problems.
Looking forward to your opinions and advice!
sifope
24 Feb 2023 11:26
nohau61 schrieb:
the surface shows noticeable color differences in several areas
Before you file a complaint directly: Have you checked whether the color variations are purely superficial or if they actually affect the material’s structure? Sometimes such spots are only visible due to lighting conditions or the environment and may fade after a few days.
nohau61 schrieb:
The color fluctuations look like manufacturing defects
That could be the case, but IKEA produces on a mass scale, so occasional minor flaws do happen. The key question is whether the defect affects functionality or only appearance. Complaints are usually possible, but IKEA will likely assess whether the flaw is significant or not.
Personally, I would wait to see if your impression remains stable, since filing a complaint often means returning the item, waiting for a replacement, and possibly some hassle. On the other hand, if you insist on a flawless item and find the issue really bothersome, you are entitled to take action.
If you do file a complaint, document the defects carefully with timestamps and descriptions—that helps communication. Still, I would never accept anything that significantly deviates from the standard quality.
Giagau
25 Feb 2023 09:48
nohau61 schrieb:
Is a complaint process lengthy or complicated?
I can answer this from personal experience: At IKEA, the complaint process is generally straightforward, especially if you have the purchase receipt. I once had a similar issue with a piece of furniture – color variations and small defects – and customer service responded quickly. A replacement part was sent, or the shelf was exchanged.
It is important to describe the defects to customer service as precisely as possible. Usually, they send a return label so you can send back the defective part. The duration can vary depending on product availability, but it usually does not take longer than a few weeks.
I therefore advise you not to accept color defects if they affect the overall visual impression and bother you. Furniture is an investment in living quality, so compromises should be avoided.
If you really need the item urgently, you can also propose a solution, for example a partial discount or a later exchange – IKEA may be open to negotiations in some cases.
anfeteo
26 Feb 2023 14:03
I would like to provide a clear, structured overview of the steps to take if someone like nohau61 notices color defects on a KALLAX shelving unit:
1. Check the condition carefully: Proceed systematically, note all defective areas, and describe the color, size of the stain, and its location. It is important to document the issue clearly.
2. Document: Take photos (even if not required here, very helpful for personal records), and write down the date and time when the defect was noticed.
3. Contact customer service: Reach out to IKEA by phone or online. Highlight your documentation and specifically ask about the possibility of an exchange or replacement delivery.
4. Check goodwill policies: IKEA is known for relatively accommodating returns, although this usually applies only to unused or nearly new items. Refunds are not always provided, but in some cases, a replacement part may be offered.
5. Consider your options: If the color defects do not affect functionality and you urgently need the furniture, you can choose to live with the situation temporarily while keeping the claim open.
Summary: Be clear about what matters most to you—appearance or use. In your case, making a claim is completely justified due to the obvious quality defect. IKEA usually does not complicate this process if you remain clear and organized.
Giagau schrieb:
Furniture is also an investment in quality of living, so compromises should be avoided.
I fully agree. It is always worth insisting on the standard you expect for the price.
boelnu
27 Feb 2023 08:21
nohau61 schrieb:
I actually want to keep the piece of furniture because I urgently need it, but such a paint stain really affects the overall appearance.
I completely understand; situations like this are always frustrating—especially when you rely on the furniture and don’t have time for lengthy returns.
I would still recommend contacting IKEA. Customer service often shows flexibility here: you might receive a small discount, a voucher, or a replacement later on.
Even if you decide to keep the shelf for now, it’s good to have the complaint officially registered. If the defect worsens or other issues arise, you’ll be in a better position.
Sometimes maintaining a polite and factual tone helps, as this often leads to more goodwill. You’re not alone—these kinds of color variations seem to happen fairly regularly.
I hope you find a suitable solution quickly! 🙂
