ᐅ My KALLAX unit does not fully slide flush against the wall.
Created on: 20 Jan 2023 18:27
jorge4
jorge4
20 Jan 2023 18:27
I have the following issue with my IKEA KALLAX shelf unit: when I try to push it against the wall, it stops about 2 to 3 cm (1 inch) away, as if something is blocking it. The shelf is assembled correctly, all screws are properly tightened, and the feet are firmly resting on the floor. I measured to check whether the back panel of the shelf is straight and also the wall surface where I place it is even. Still, the shelf won’t sit fully flush against the wall.
I have already considered possible reasons such as uneven flooring, protruding or thicker baseboards / skirting boards, or small raised edges on the back of the shelf, but haven’t found a definite cause yet. Has anyone experienced something similar or knows typical reasons why a KALLAX won’t fit completely against the wall? I would appreciate any tips for troubleshooting or advice on what else I should check.
andre3
20 Jan 2023 19:03
jorge4 schrieb:
I have already considered possible reasons like uneven flooring, potentially bowed or thicker baseboards, or small raised edges on the back of the shelf
It’s good that these potential causes have already been checked. However, it is often a combination of several minor factors that together prevent the KALLAX shelf from sitting flush against the wall.
1. Double-check both the floor and the back of the shelf for levelness using a spirit level. Sometimes there are slight irregularities that go unnoticed in everyday use.
2. Inspect the baseboards carefully, including any adhesive residues underneath that might increase thickness.
3. Some KALLAX models may have a slightly uneven back panel, especially if it wasn’t nailed or screwed in firmly enough. A gentle adjustment can help.
4. If present, floorboards that have warped due to moisture can also cause minor issues.
5. Finally, the installation or placement location allows for the adjustment of shelf feet. Adjustable feet (if available) should be fully extended to reduce the gap.
Summary: Precise measurement and checking of the surroundings, as well as the back panel, floor, and feet, are key to resolving the issue. If all these points have been verified, a small modification to the shelf frame might be necessary.
TEBILO
21 Jan 2023 09:18
andre3 schrieb:
A combination of several small factors
sums it up very well.
I recommend the following systematic approach:
1. Empty the shelf and lift it completely to check the feet. Are they plastic gliders or adjustable leveling feet? The latter should be adjusted so that the shelf surface is completely level.
2. Check the floor using a two-axis spirit level: lengthwise and crosswise. KALLAX shelves often aren’t entirely rigid; slight sagging can usually only be felt under load.
3. Remove the back panel and carefully inspect all around for any nails or edges of the wood panels sticking out. These back panels are usually thin and may have small irregularities.
4. Walls in modern apartments are never perfectly straight—measure the distance between the wall and the shelf using a tape measure and check if it is consistent along the entire length.
5. Check the shelves including the side panels for warping. Sometimes slight manufacturing tolerances are the cause.
6. A frequently overlooked point: baseboards along the wall. Even if they appear flat, profiles, corners, or improper installation can increase the gap between the shelf and the wall.
Question: Have you illuminated the area behind the shelf with an LED flashlight? This often reveals protruding spots that remain hidden in everyday use.
If you like, you could also share the size and variant of the KALLAX, which helps to provide more specific advice.
JONSON
22 Jan 2023 13:44
TEBILO schrieb:
Question: Did you illuminate the area behind the shelf with an LED flashlight?
This is a very practical tip for troubleshooting. I would add that it can be helpful to slide a thin, rigid feeler gauge or ruler between the wall and the shelf to identify any localized obstructions.
Also: If the KALLAX legs do not allow height adjustment, you could place small, thin felt pads or spacer shims under the rear legs to slightly tilt the shelf and bring it fully flush against the wall.
If a gap still remains despite all tests, there may be a slight deformation of the back panel that can be corrected by gently bending it or replacing it.
Finally: If the shelf uses wooden or particleboard backing panels, moisture can also cause minor warping, which can be observed from inside the shelf.
