ᐅ My KALLAX became dull after using cleaning products – any ideas?
Created on: 6 Feb 2016 19:37
fugeglaHello everyone,
I recently cleaned my KALLAX cabinet with a common household cleaner to remove some light stains. Unfortunately, after cleaning, the surface has become quite dull, almost as if a matte layer is covering it, which has significantly damaged the natural finish. The material also feels a bit rougher than before.
I didn’t let the cleaner sit for long, just wiped it off as usual. Can anyone explain why this might have happened and if there is a way to restore the original surface of the KALLAX cabinet? Are there specific cleaning products to avoid or any tips on how to refresh the surface?
Looking forward to your experiences and suggestions, thanks in advance!
fugegla schrieb:
Unfortunately, after cleaning, the surface became quite dull, almost as if a matte layer has formed over it, which significantly ruins the natural finish.This issue often occurs when aggressive or unsuitable cleaning agents are used on coated furniture surfaces, such as many KALLAX variants that have a melamine resin-coated finish.
The most likely cause is that the cleaning product contains ingredients that attack or microscopically roughen the protective layer of the surface. Especially chlorine-containing or alkaline cleaners can weaken the surface structure, causing it to appear dull.
To restore the surface, I would first recommend wiping it thoroughly with clean water and a soft cloth to remove any remaining cleaner residues. Afterwards, it often helps to gently treat the surface with a furniture polish or specialized plastic care products that contain silicone or waxes. Be sure to choose a product suitable for melamine or resin-coated surfaces.
To further improve the surface, you could also very carefully rub it with a very fine abrasive pad (e.g., super fine steel wool grade 0000), but only try this if you are confident that no visible scratches will occur.
It would also be important to know exactly which cleaning product you used (brand, composition?) so that the aggressiveness of the ingredients can be assessed.
In general, I advise against using aggressive or alcohol-based cleaners for KALLAX. Instead, mild soapy water or special furniture cleaners designed for laminated surfaces are recommended.
One more question about usage: was the cabinet dried immediately after cleaning? Sometimes moisture penetrating the surface can also cause a temporary dull effect.
Feel free to provide more details, so I can help you more specifically.
minKarson7 Feb 2016 08:12If the surface has become dull, furniture polish containing silicone often helps. This can quickly refresh the finish.
Otherwise, avoid cleaning agents designed for melamine-coated surfaces – it is best to use a neutral soap solution and wipe dry immediately.
fugegla schrieb:
Can someone tell me why this might have happened and if there is a way to restore the original surface of the KALLAX cabinet?Good morning!
I’m quite familiar with the problem of dull spots on melamine-coated furniture, especially when a too strong cleaning agent has been used. The coating is usually not flexible and reacts sensitively to solvents or acidic cleaners. This results in exactly the effect you described – a matte, rough-looking surface.
Here’s a test: take a small, hardly visible corner and try cleaning it gently with a mixture of warm water and a mild dish soap. Wipe the area carefully and then dry it thoroughly. If the cabinet looks better afterward, the cleaning product was probably too harsh.
If you feel the surface is slightly roughened, you can gently polish it using a microfiber cloth and a bit of furniture polish. Some people also report success with a few drops of natural olive oil, letting it sit briefly and then wiping it off – this can help smooth the surface without causing damage.
Avoid harsh abrasive cleaners or alcohol at all costs! They can quickly cause scratches or permanently damage the protective layer.
If none of this works, you might need replacement panels or consider using color-matched adhesive films like those available for IKEA furniture. But until then, it’s best to try all the milder options.
I hope this helps you 🙂
