ᐅ Is it worth using edge protectors for the lower edges of KALLAX units?
Created on: 6 Sep 2024 08:37
sikeju
sikeju
6 Sep 2024 08:37
I have a question regarding the durability and protection of my IKEA KALLAX shelves, specifically about the edges of the lower sections that often come into contact with the floor or are frequently touched. I am considering whether it makes sense to install edge protectors on the lower edges of the KALLAX units.
Has anyone had experience with whether such edge protection is really worthwhile? I am especially interested in whether the protection effectively prevents scratches, chipping, or other damage, and if the installation or appearance is affected.
I would be very grateful for various opinions and tips!
gregto
6 Sep 2024 09:11
Hello sikeju,
Regarding your question: "Is edge protection worth it for the lower edges of KALLAX?" – in my experience, definitely yes. Especially for furniture that is frequently moved or cleaned at floor level, the lower edges can get damaged quite quickly. Edge protectors made of soft PVC or silicone absorb impacts and prevent chipping.
Keep in mind, however, that depending on the color and material of the edge protector, the visible edge may stand out, which some might find unattractive. Installation is usually straightforward, either self-adhesive or clip-on.
Additionally, the edge protection also guards against moisture that can easily rise from the floor. So if you care about long-term preservation, it is a good investment.
If you want more details, for example about which types are particularly recommended, feel free to ask.
Kinbu
6 Sep 2024 09:22
A brief statement from me as well:
Edge protectors can prevent damage to KALLAX shelves, especially if there are children in the household or if you frequently mop the floor. The lower edges are vulnerable to impacts and scratches from vacuum cleaners and similar equipment.
However, the benefit also depends on how the shelf is used. If your shelf remains stationary and is not handled often, the effect is rather minimal.
INGRID34
6 Sep 2024 10:17
I would say: Yes, it’s worth it. My low KALLAX edges got damaged quickly. Edge protectors provided immediate visible protection.
Installation was easy and looks good.
Lorukeo
6 Sep 2024 12:40
From a practical standpoint, installing edge protectors on the lower edges of KALLAX units makes sense when there is a risk of mechanical stress or exposure to moisture.
The edge protector acts as a buffer against impacts, abrasion, and prevents chipping of the melamine surface. This is particularly relevant for shelves placed on parquet or tile floors, where scratches can occur from cleaning equipment or rearranging furniture.
Another consideration is material compatibility: the installation should avoid damaging the edges with adhesives or screws. Self-adhesive protective profiles are usually easy to remove without issues.
In conclusion, if the usage scenario increases the risk of damage, the additional cost for edge protection is justified and sensible.
flo-Theres
7 Sep 2024 07:31
In my experience, the lower KALLAX edges particularly benefit from edge protectors when the shelves are placed in a children's room or in hallway areas where they are heavily used. The protective profiles significantly reduce visible damage.
If you care about aesthetics, you should carefully consider the choice of profile. Some options look rather bulky, while others are more discreet.
Overall: yes, in my opinion, it is worthwhile if the intended use justifies it.
