ᐅ My hallway shelf is a KALLAX—how can I prevent it from rattling or making noise when the doors close?
Created on: 2 Feb 2018 09:14
Juken
Hello everyone, I have a KALLAX shelf unit in the hallway that unfortunately makes an unpleasant rattling noise when the doors are slammed shut. The doors are made of glass and hang somewhat loosely in the frame, which seems to amplify the sound. My question is how I can effectively prevent this rattling without making major modifications or completely rebuilding the shelf? Are there any specially designed dampers, cushions, or setup tips that could help here? I would appreciate practical and straightforward solutions!
Hello Juken,
I have a lot of experience with IKEA furniture, especially the KALLAX series. The rattling often comes from missing or worn-out dampers. It is also important to properly align the door hinges. If your KALLAX is not yet equipped with soft-close fittings, you can retrofit these – they come as a set and significantly reduce the slamming noise.
If you prefer to avoid modifications, I recommend attaching small silicone bumpers to the inside of the doors, as they can effectively dampen the noise.
One more tip: Sometimes adjusting the door slightly so it doesn’t hit the frame too hard also helps.
Good luck!
Good luck!
Thank you for the tips so far!
A brief overview of my situation: The hinges seem sturdy but do not have soft-close, which I had expected. The doors have very little padding on the edges, which causes a hard impact. I’ll look into silicone bumpers.
One more question for the group: Are there any specific recommendations for the type or dimensions of bumpers for the KALLAX? They shouldn’t be too thick but still provide enough cushioning.
Also, adding soft-close fittings seems technically feasible but possibly quite involved. Has anyone had experience with how easy or difficult it is to retrofit soft-close on a KALLAX?
Juken schrieb:
Are there any specific recommendations for the type or size of bumpers for the KALLAXFor the KALLAX, I usually recommend silicone or foam rubber bumpers about 3-4 mm thick (0.1-0.15 inches). They are thick enough to provide cushioning but thin enough to allow the doors to close properly. Both round and square shapes work, depending on how much contact area you need.
Juken schrieb:
Retrofit soft-close fittingsRetrofit is not a standard solution for the KALLAX, as the doors are often mounted with simple hinges. You would need to buy hinges with a soft-close function and replace the old ones. It’s technically possible but requires precise work and some DIY skills. Make sure to check the hinge types, as they must match the door panels.
If you have some basic DIY experience, you can give it a try; otherwise, bumpers are often the better option.
RUBEN54 schrieb:
Converting to soft-close fittings is not technically impossible, but it does require some craftsmanshipExactly! But hey, don’t panic! 🙂 Doing it yourself always feels really great, and if you get stuck, we’re here to help.
I always cheer when a KALLAX has soft-close now!
The rubber buffers are my secret tip, mainly because they don’t damage anything and can be completely undone without leaving any residue.
Jamalli schrieb:
questioning whether the rattling is caused rather by loose hinges or misaligned doorsThat’s true. It is also important to identify the root cause before installing dampers. If the hinges are indeed loose, buffers will only provide limited help. In a modular system like KALLAX, a slight readjustment of the hinges can make a significant difference.
Additionally, it is worth considering whether minimal adjustments to the hinge fittings could make the doors fit more tightly to prevent them from banging.
