ᐅ After moving, the KALLAX doors no longer fit properly for me – any tips?
Created on: 4 Apr 2020 09:12
kihannes
I recently moved with my KALLAX shelving unit from IKEA and now I’m facing a small issue that’s quite frustrating: the doors I installed on the unit no longer close properly and don’t fit flush against the cabinet edges. Everything is new, and I haven’t made any significant changes to the doors or the unit itself.
I suspect this might be related to the new spatial conditions, slight warping, or a minimal dimensional deviation in the floor or wall. Are there any tips or tools here in the forum that could help me adjust or fix the doors without having to buy new ones or rebuild the whole shelving unit? I’m thinking that small wedges, adjustment screws, or similar modifications might help.
Has anyone had experience with this? I look forward to your advice and suggestions!
kihannes
FLONE41
4 Apr 2020 11:47
I completely understand the frustration. This kind of issue can really slow you down and be annoying. From my personal experience, it’s often a combination of slight warping in the frame and small unevenness in the room that causes the problem.
I was almost driven to despair once, until I adjusted a fixed hinge on one side to get the door to close properly despite all the inaccuracies.
Small imperfections can make you feel uncertain, but I believe with some patience and the right adjustments, you can manage it. 🙂
Surela
4 Apr 2020 12:03
A few technical notes on the topic:
1. Levelness Check: Use a digital level or a measuring rod to check the furniture on multiple axes. A gentle tap on the base can indicate whether the shelf is resting only at specific points.
2. Hinges: KALLAX door hinges are usually concealed and have limited adjustability. For more significant fitting issues, it is recommended to install hobby or model-making hinges with greater adjustment options (these need to be purchased separately and some modification is required).
3. Material-Related Dimensional Changes: Wood-based materials adapt to humidity. Checking the indoor climate helps to determine whether the doors might be expanding or contracting.
4. Spacers: Thin plastic or rubber strips can be attached inside along the edges and can be removed or repositioned if needed.
5. Minor floor unevenness – often just a few millimeters (inches) difference can cause doors to close unevenly.
Does this help so far? Are there any particular details regarding the doors you are using?
kihannes
4 Apr 2020 13:17
Tevin schrieb:
First, check whether the shelf itself is still perfectly vertical
Thanks for the tip! Yes, the shelf is indeed not completely straight—I can tell even when I measure with a spirit level. The floor isn’t 100% level, which I had already suspected.
I have a model with concealed hinges, and so far I’ve found very few options to adjust the doors, apart from a small screw that doesn’t allow much movement.
The spacer idea sounds interesting. Could you recommend something that can be easily attached without damaging the door?
Maybe my shelf is more crooked than I thought. In that case, I would try using felt or foam strips inside the door frame to help with closing.
What do you think is the best way to stabilize the shelf without taking it apart?
Thanks so far!
Chendu
4 Apr 2020 13:48
Felt pads or self-adhesive foam strips from the hardware store are perfect for this. Simply stick them on the inside edges of the door where it rubs.
reoleon47
4 Apr 2020 14:04
Cool that you reached out with your KALLAX issue! 🙂
I had the same problem after moving! My solution was to stick small self-adhesive felt pads on the edges of the doors where the fit to the shelving unit was a bit too tight. That really helped a lot!
You can really notice how the doors close smoothly again and no longer get stuck 🙂 So give it a try—it’s inexpensive and quick to do! Good luck!
GALEO4
4 Apr 2020 14:44
karus66 schrieb:
The fundamental problem lies in the design and minimal tolerances
Okay, that’s a valid point.
Still, I think that for such a seemingly simple system, IKEA could design the doors to easily accommodate even small variations, instead of shifting the problem onto the customer with “do-it-yourself adjustments and fine-tuning.”
Maybe a flexible rubber gasket that adapts and seals would make a big difference. But instead, we get rigid doors with minimal adjustability.
If it were up to me, I would completely rethink the KALLAX concept with doors.
