ᐅ Malm Drawer Slide Broken – How Do I Replace It?
Created on: 22 Apr 2022 09:17
Domo47
Hello Community,
I have the following problem: The drawer slides on my Malm dressers are damaged, which results in rough movement, occasional detachment of the drawers, and generally difficult opening and closing. The slides seem to be wear parts after several years of use.
My question for you is: What is the best way to replace these Malm drawer slides?
I am interested in specific tips for disassembly, which screws need to be removed, whether I need any special tools, how to identify the correct replacement parts, and how to reassemble everything neatly so that the drawer does not stick or wobble.
Is there anything particular to watch out for with this model?
Thank you in advance for your detailed advice!
fepau
22 Apr 2022 15:47
Hey Domo47,
great that you’re taking on the task yourself! When I replaced drawer slides in a similar situation, I followed this approach:
1. Document everything thoroughly with photos – as a memory aid in case something goes wrong 😉
2. Spare parts. I found great replacements online, often universal ball-bearing drawer slides. They fit perfectly and are usually cheaper than original parts!
3. Preparation: Remove the old slides and clean the cabinet thoroughly. Fine sandpaper works really well to remove old paint residues.
4. During installation, the key for me was to align the slides precisely – a ruler helps, and sometimes an adjustment screw can be useful if the slide can be fine-tuned.
The feeling when the drawer slides smoothly again is just fantastic! 🙂
Fingers crossed, you’ll manage it!
tinau
22 Apr 2022 16:22
Domo47,
when replacing the drawer slides, make sure to install the drawer at the correct height.
Sometimes there are small adjustment screws or settings on the slides that you should use to prevent the drawer from sticking or wobbling.
Equally important: do not overtighten the screws.
Good luck!
glamo
22 Apr 2022 17:08
Domo47 schrieb:
A guide rail is bent and stuck, and some of the ball bearings in one guide have partially fallen out.
The issue with bent rails is particularly tricky. Even if you order replacements, it can be helpful to carefully inspect the old rails to identify the cause of the deformation. Is it due to overloading, incorrect installation, or material fatigue?
Furthermore, ball bearings are very important: when sourcing replacements, make sure to choose high-quality bearings—cheaper products often lead to premature wear.
Regarding alignment: measure the internal dimensions of the cabinet and compare them with the guide dimensions you intend to install. Small deviations can significantly affect performance. Also, pay attention to the positioning of the screw holes; sometimes, slightly adjusting the drill holes forward or backward can improve smooth operation.
My question to you: do you have any specialized tools available, such as a screwdriver with a magnetic tip, to safely remove and install small screws?
Laukau5
23 Apr 2022 09:14
Hello Domo47,
I would like to add an important point that many people overlook during DIY replacement work: load distribution.
Malm drawers are quite heavy, especially when fully loaded. Therefore, the drawer slides not only need to be aligned but must also be able to evenly distribute the load.
I recommend leaving a small gap of about 2–3mm (0.08–0.12 inches) between the slide and the frame before tightening the screws, then checking from multiple angles how the drawer fits.
Additionally:
Before installation, you should inspect the slides for any damage. A light cleaning and lubrication of the ball bearings before assembly also greatly improves their lifespan.
One more question: Are you using the model with self-closing slides or the regular ball-bearing ones? That makes a difference during installation.
Best regards!
GLALEO
23 Apr 2022 11:29
Hey Domo47,
that’s great that you’re putting in the effort! 🙂 I had a similar issue with my dresser and simply switched to high-quality replacement drawer slides that run smoothly!
The best part is: with a bit of patience during alignment, you can achieve the perfect sliding motion. After that, opening and closing is really enjoyable!
Keep at it, it’s definitely worth it! 🙂
