ᐅ Location of a city villa or detached single-family house on a 500 m² rectangular plot
Created on: 17 Jan 2020 18:03
Tolentino
Dear all,
after sharing the floor plans of my possible hamster cage with you in the other thread , here comes the next thread (thanks again for all the constructive suggestions there).
Just so you know, the semi-detached house is not off the table yet, as this plot of land is highly sought after and it’s not clear whether it will work out. But this one would be my favorite.
Now to this plot. For now, I’m mainly concerned with where and roughly how the house should be positioned on this plot.
Plot size: 500 m² (5400 sq ft)
Slope: none
Site coverage ratio: 0.2
Floor area ratio: 0.4
Building envelope, building line and boundary: 5 m (16 ft) from the street, 3 m (10 ft) from neighbors
Edge development: allowed for garages and sheds, none existing on the plot
Number of parking spaces: 1-2
Number of floors: 1.5–2.5
Roof shape: no preference
Architectural style: no preference
Orientation: aligned parallel to the street
Maximum heights / limits: ridge height max. 9 m (30 ft)
Below are the site plans I created myself based on the details from the listing.
This is a rough overview of the plot with building boundaries and dimensions.
Site plan: green center outlined by red frame, street names on the left and compass top left.
My question is: where to put the house?
The broker suggests placing it towards the back, since you already have the 5 m (16 ft) setback at the front and would “gain” about 3 m (10 ft) of garden. My partner doesn’t like this because of the visibility from the street. I say: privacy screen! But I also think, a fence too high might create a prison-yard feel.
But even if you follow this suggestion, I wonder if a more square floor plan (-> town villa style) would be better?
Like this, for example:
Floor plan: street on the left, orange buffer zones, green area, central grey building (100 m²).
Then parking space might be tricky, right?
Or upright like this?
Floor plan of a plot with orange buffer zones, green yard and grey building block.
I really want as much of a west-facing view and garden as possible. I tend to be an evening person and that side is less built up, due to the road. So I think more light comes through.
But the narrow floor plan caused lots of problems with the semi-detached house already. Well, here you could build longer instead.
What do you think?
Tolentino
Alessandro
9 Jul 2021 08:52
A 4-core shielded cable for the AT sensor would be completely unnecessary! If you say it’s relatively far from the utility room, then depending on the sensor element, the line resistance should not be ignored. In that case, using 3- or 4-core cable makes sense again.
K1300S9 Jul 2021 11:58
There is nothing shielded there! This is just standard doorbell wire, probably four-core simply because there wasn’t any two-core wire available at the time. But for just a few meters, there’s no need to worry that the measurement won’t work because of that—if it is indeed for the outdoor temperature sensor, which is quite possible.
Tolentino9 Jul 2021 12:09
I can’t think of any other purpose for this. Especially since it’s missing on the other wall according to the plan, it seems quite likely. But the master electrician will be back from vacation soon, so I’ll ask him then.
K1300S9 Jul 2021 12:11
Normally, it should face the north side, or otherwise northeast if true north is not available. Northwest would generally be the less favorable option.
Tolentino9 Jul 2021 12:25
Yes, that’s why the plan was northeast. But I assume that since a control unit will be installed in the living area, they placed the sensor there because it was the shorter route after all.
K1300S9 Jul 2021 12:29
That may be true, but the location should not depend on where the least effort is required. Conveniently, we have the boiler room on the north side, so the distance is very short there, but even if it were on the other side of the house, I would still place the sensor facing north. Otherwise, the readings would not be accurate.
