ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
Alessandro
6 Apr 2020 12:46
I have another "problem."
This time it’s about the freezer. It is located behind the kitchen in the pantry, which can be accessed through the kitchen area and also from the hallway on the other side.
Despite the pantry being 7sqm (75 sq ft), it gets very warm because of the freezer, which of course increases electricity consumption, and it isn’t possible to store potatoes or similar items there.
There is no underfloor heating installed in the pantry, and the roller blind is kept permanently down. The temperature is already 21°C (70°F), as the afternoon sun shines directly onto the side of the pantry.
I’m wondering what it will be like in the summer and whether I should move the freezer somewhere else. However, I don’t have a basement, and it is warm everywhere...
What maximum temperatures can the freezer handle without damage or excessive energy use?
Ibdk146 Apr 2020 15:27
Did you seriously think you could store potatoes or similar items there? In a pantry next to the kitchen, in rooms that must never get cold and are regulated accordingly, you can’t expect a few square meters to stay cool – maybe even below 10°C (50°F).
The freezer obviously generates some additional heat. I have no idea where else you could place the freezer if you don’t have a basement.
Outside, in the garage?
Alessandro
6 Apr 2020 15:42
The thing with the potatoes wasn’t meant too seriously, of course.
What’s important to me is that the area near the freezer’s waste heat doesn’t eventually reach 30°C (86°F).
Could that happen, or is it nothing to worry about?
guckuck2
6 Apr 2020 17:06
Most people probably stop working at 16°C (61°F), and at the latest at 10°C (50°F).
They usually can handle heat up to 32°C (90°F). I wouldn’t worry about it.
haydee
7 Apr 2020 07:04
I only have this problem when I hold objects fairly high under the water stream.
Lumpi_LE
7 Apr 2020 12:27
We also have a Blanco Linus, and when you open it, such a rush of water comes out that if you’re not careful, the kitchen ends up flooded... plus, it’s been dripping after just over 2 years... great quality.
In the utility room, I installed one myself for 50€ from Amazon, which works much better.
