ᐅ Using Kallax as a Basement Shelf – Does It Withstand Moisture?
Created on: 19 May 2023 09:13
Saumeinolf
Hello everyone, I’m considering using an IKEA Kallax shelf as a basement storage unit. I have a question about how well the Kallax furniture handles moisture. My basement is not damp, but there is often higher humidity, especially in winter. I’m particularly interested in whether the shelf warps, becomes infested with wood-boring insects, or if the panels absorb moisture. Has anyone had experience with Kallax being used long-term in a basement without additional protective measures? I would prefer not to have to treat or replace the shelf every year. Thanks in advance for any helpful insights!
Saumeinolf20 May 2023 11:25BOLUKEO schrieb:
Alternatively, you can impregnate the Kallax, but that is additional effort.That's exactly what I was thinking about. Does anyone have tips or experience with sealants that work well on Kallax (particleboard with melamine resin coating) to repel moisture? Should it be applied directly to the cut edges or surfaces, or is a breathable layer sufficient? I would also be interested to know if it really helps in the long term.
Saumeinolf schrieb:
Does anyone have tips or experience on which sealants work well on Kallax ...?I recommend a combination for Kallax:
- Above all, seal the cut edges well with a water-repellent wood varnish or acrylic sealant.
- The melamine coating is resistant but difficult to treat with additional layers, so the edges are the weak points.
- It is also important to place the shelf on feet or a base to avoid direct contact with the floor and condensation.
- A breathable but water-repellent glaze is challenging because the melamine surface is already sealed. Therefore, focus on targeted sealing of the edges.
There is no long-term study, but this approach can significantly improve durability.
