ᐅ KALLAX installed in a damp room – should it be discarded immediately?
Created on: 2 Feb 2016 08:37
KugoteHello everyone,
I recently bought a KALLAX shelving unit from IKEA and am now wondering if I can place it directly in a humid room, specifically in my utility room with occasional high humidity, or if I should just dispose of it immediately.
I know the KALLAX shelving unit is made of particleboard and only covered with a melamine coating, which is probably not specifically water-resistant. I am mainly interested in whether the shelf will swell significantly, warp, or even pose health risks due to mold growth when exposed to moisture.
Does anyone have experience with the material properties and know if the KALLAX shelving unit can be used long-term in a humid room, or should I look for a fully waterproof alternative? Thanks in advance for your advice!
Kugote schrieb:
whether I can place it directly in a damp room, more precisely in my utility room with occasional high humidity, or if I should better dispose of it right away.The KALLAX shelf unit is actually made of prepared particleboard covered with melamine foil. This surface is water-repellent but not waterproof.
With constant or frequent high humidity, the material can eventually swell, especially at unprotected cut edges. This may lead to warping and loss of stability.
Kugote schrieb:
whether the shelf swells significantly from moisture, warps, or even poses health risks due to mold growth.Mold growth is unlikely with good ventilation, as long as the shelf does not get wet or remain damp for extended periods. It is important to prevent standing water or moisture penetrating the material.
Conclusion: KALLAX is suitable for occasionally humid rooms if you place the shelf slightly elevated and treat the cut edges. It is not suitable for constant moisture or permanent wet conditions.
For clarification: Melamine coating on particleboard is generally resistant to splashes of water but not to prolonged exposure to moisture.
From a technical perspective, MDF or particleboard furniture is generally unsuitable for damp rooms because it swells when absorbing moisture and loses strength.
In technical datasheets from IKEA, the material used in KALLAX is not specified as suitable for damp environments.
As long as there is no direct exposure to water and good ventilation is ensured, the functionality remains intact.
If there is a permanent moisture load, I recommend an alternative made of HPL or metal shelving.
Thanks in advance for the quick responses.
I have the shelf placed near the washing machine, where light condensation can occasionally occur, but it doesn’t come into direct contact with water.
I am now considering sealing the visible cut edges with a waterproof varnish or clear coat to reduce the risk of swelling. Does anyone have experience with this kind of post-treatment?
Would this be a practical solution, or does it not make much difference if the humidity rises occasionally?
Kugote schrieb:
I am now considering whether to seal the visible cut edges with a waterproof varnish or clear coat to minimize the risk of swelling.Yes, this is a common method to improve protection. Unsealed cut edges absorb moisture much faster.
In general, I recommend sealing all exposed edges several times with a waterproof varnish (e.g., PU varnish). A thorough coating significantly extends durability.
The shelf should also be placed on feet or spacers to prevent moisture from being absorbed from the floor.
For occasional humidity, not constant water exposure, this is a practical and cost-effective solution.
