ᐅ KALLAX does not fit the planned wall – is it possible to modify it?
Created on: 3 Feb 2020 08:47
lujepau
lujepau
3 Feb 2020 08:47
I recently bought an IKEA KALLAX shelving unit because I need the extra storage space for my living room. However, the unit doesn’t fit on the wall I intended it for. The wall is slightly shorter than the width of the shelving unit, and now I’m wondering if it’s possible to modify or rebuild the KALLAX so that it’s either shorter or better adapted to the wall.
I’m especially interested in whether anyone has experience shortening KALLAX components or assembling them differently without compromising stability or appearance. I’ve already considered whether it’s possible to cut the side panels or if there are alternatives, like modifying it with smaller compartments.
If anyone has tips or even instructions on the best way to handle this — for example, what tools are needed or what to watch out for — I would really appreciate it.
Best regards!
miAlessio
3 Feb 2020 09:05
Hello lujepau,
your question about modifying the KALLAX shelf unit is very well formulated. I have some experience with IKEA furniture and can offer you a few tips.
1. The KALLAX cannot simply be shortened in width because it consists of prefabricated wooden panels and frames that are glued and fixed together with dowels. Cutting the side panels is therefore risky and can significantly affect the stability.
2. An alternative option is not to use the entire shelf as a single piece but to buy several smaller KALLAX units and join or combine them. This allows for more flexible dimensions.
3. If you are handy, you can remove individual side panels and, for example, customize the shelves to size. For this, you should use high-quality tools and carefully finish the cut edges to avoid splintering.
4. When modifying, always pay attention to the load-bearing capacity. KALLAX units carry weight mainly through the side panels. If you remove or shorten these, you will need to add extra reinforcement afterwards.
In summary: fully shortening the unit is complicated, but with a clever combination approach or professional cutting, you can adjust the shelf.
If you like, I can send you a detailed guide or links to tutorials.
Kabau
3 Feb 2020 09:18
KALLAX units are not easy to cut. It’s better to buy smaller modules and place them side by side.
Le-so
3 Feb 2020 09:42
Cutting off works, but stability suffers. Reinforcing with brackets or metal braces helps.
SUBEN60
3 Feb 2020 11:25
miAlessio schrieb:
KALLAX cannot simply be shortened in width because it is made from prefabricated wooden panels and frames
I completely agree with this. Additionally, it is important to note that IKEA uses composite materials with particleboard and melamine coating for KALLAX, which are difficult to cut professionally without damaging the edges.
For a safe modification, I strongly recommend using a jigsaw with a fine-tooth blade, followed by careful sanding and sealing the cut edges with appropriate edge banding or waterproof varnish.
Alternatively, modular construction options with smaller KALLAX units, as already mentioned, might offer a better solution.
Please keep in mind that any alteration is not approved by the manufacturer and may void the warranty.
mifra
3 Feb 2020 12:16
Kabau schrieb:
Better: buy smaller modules and place them side by side.
Exactly. I would also recommend choosing two or more smaller modules instead of one large shelf unit. This increases flexibility for future rearrangements and avoids the effort of cutting and finishing.
If you want to make the most of the wall space, you can also combine modules of different heights or widths, as KALLAX stacks well.
