ᐅ Kallax has developed a persistent moldy odor after water exposure – what can be done?
Created on: 9 Dec 2016 09:03
Canki2
I have a Kallax shelf from Ikea that unfortunately developed a persistent musty smell after water exposure. The shelf got wet a few weeks ago due to water leakage, and although I thoroughly dried it, the unpleasant odor remains.
I suspect that the fiberboard or particleboard inside absorbed moisture and now mold or mildew is causing the smell. I am particularly interested in methods to eliminate this musty odor permanently without having to replace the entire shelf.
Does anyone have practical experience with cleaning or treating furniture like this? Are there any recommended home remedies or professional products for these kinds of odors?
Thank you in advance for your help!
raKatharin
9 Dec 2016 17:49
Have you tried baking soda? Simply place a bowl of baking soda on the shelf. It helps absorb odors.
Also: ventilate the area well and, if necessary, dry furniture with a fan.
If you want to get rid of the smell, this is the first and easiest method.
silako
10 Dec 2016 08:21
Baking soda only absorbs odors on the surface. If the causes are deep within the material, its effectiveness is rather limited.
Furthermore, I have some doubts: Are you sure it’s mold, or could bacteria or wood decay processes be causing the musty smell? In the latter case, vinegar and similar remedies don’t always help.
Has anyone heard of ozone treatment as a solution? It is said to permanently remove odors from furniture by breaking down organic compounds. However, the costs and effort involved should be taken into account.
kuben
10 Dec 2016 09:44
In my experience, there is a clear procedure to effectively deal with musty odors in Kallax furniture after water exposure:
1) Complete Drying: As mentioned, the best method is using a dehumidifier plus a fan for 3-5 days.
2) Visual Inspection: Carefully check edges and back panels, and if necessary, wipe areas with mold using alcohol (denatured alcohol).
3) Odor Neutralization: Place bowls of baking soda inside and around the compartments, replacing it several times.
4) Surface Protection: Apply a special edge sealant, available at hardware stores, to unsealed cut edges to seal them.
Important: Unfortunately, Kallax boards are not designed for repeated exposure to moisture. Consider whether this treatment is only a temporary solution or if replacement will be necessary in the long term.
As an alternative for heavy infestations:
- Simply use an anti-mold spray and then ventilate thoroughly for an extended period.
- Dry sanding followed by sealing.
This is often the best compromise between effort and results.
CHENNE
11 Dec 2016 13:05
Additionally, I would like to point out that the moisture damage and the resulting musty odor in Kallax furniture are usually caused by edges and joints where water penetrates the wood fiber material.
One way to combat the odor is to treat the surface with a mold and odor blocker based on silicone. These products penetrate deeply, preventing the growth of microorganisms and the release of musty smells.
Make sure to dry thoroughly before application and follow the manufacturer’s instructions.
Furthermore, extended storage in a very dry environment or using a drying device with adsorption function can help.
Be cautious with aggressive cleaners, as they may damage the melamine.
Canki2
12 Dec 2016 08:56
kuben schrieb:
Unfortunately, Kallax panels are not designed for repeated exposure to moisture
Thanks to everyone for the tips and insights! I can see that the musty smell in such cases is very persistent and difficult to remove, especially around the unsealed cut edges.
Next, I will try a combination of thorough ventilation, baking soda, and cleaning with denatured alcohol. If that doesn’t help, I will probably consider treating the edges with a protective coating.
If I eventually have to replace the shelf completely, I will take your advice into account and maybe choose materials with better moisture resistance ;-)
Thanks again for all the helpful and factual contributions!
