ᐅ Any experiences with damp mold growth on KALLAX laminate flooring?
Created on: 21 Dec 2024 10:37
tanfa
Hello everyone, I have recently noticed that some areas of the laminate surface on my KALLAX shelf are developing a damp mold buildup. The shelf is located in a slightly more humid room, and I’m unsure how to best address this issue. Has anyone experienced damp mold growth on KALLAX laminate before? I’m particularly interested in how to effectively and permanently remove the mold, whether the material can suffer lasting damage from the moisture, and how to prevent this mold from returning. I would appreciate any advice on cleaning and avoiding further damage!
Great thread!
I understand that this is causing frustration for you. Mold on furniture is always a problem that takes away the comfort of home. I also think it’s important not to lose hope and to carefully investigate step by step how the moisture is entering.
Keep in mind: KALLAX furniture is not designed to be placed permanently in damp rooms. If possible, consider moving the shelf to a drier location.
Do you have windows or ventilation options in the room? Depending on the situation, a portable solution might also help. Stay vigilant to keep the indoor humidity consistently low!
Properly treating mold on laminate surfaces ensures that the root cause is addressed; otherwise, cleaning alone will not provide a lasting solution. Here is my brief guide:
1. Problem Analysis: Measure indoor humidity, if possible with a hygrometer, to determine if the air moisture level is above 60%.
2. Surface Cleaning: Treat with an appropriate product, such as hydrogen peroxide-based cleaners or specialized mold removers for laminate.
3. Drying: Use warm air for direct drying to quickly remove residual moisture.
4. Prevention: Improve ventilation (air out several times daily) and, if necessary, use a dehumidifier.
I strongly advise against regularly using harsh chemicals like chlorine-based cleaners on KALLAX, as these can cause surface discoloration or permanent damage.
Wow, there are already some great posts here! 🙂
I also had a similar problem with my KALLAX in the kitchen due to cooking steam and moisture. It was really annoying. What worked very well for me was regularly leaving a window open (yes, not pleasant in winter, but it helped a lot) and also using a small fan heater that blew warm air around the shelving unit. The mold disappeared quickly afterward.
Exactly! And don’t panic, it can definitely be managed! 🙂
Jensson schrieb:
"Prevention: Improved ventilation (airing out several times a day) and, if necessary, use of a dehumidifier."
A small addition from my point of view, in case anyone wants to treat the surface carefully:
Cleaners containing bleach are effective in the short term but can damage the melamine coating, potentially causing yellowing or roughness. Also, after cleaning, no moisture should remain on the surface, as it can act like "glue spots" for new mold.
For those who only clean the affected area superficially, I recommend following up with a treatment using wood care oil or melamine protective wax to reseal the surface.
Have you checked whether the mold has also developed in the corners or back panels of the shelf? Moisture can easily remain "hidden" especially in those areas.
Palenar schrieb:
"I first tried to remove the mold with a bleach cleaner, which was effective but also slightly damaged the surface."
Thanks to everyone for the many helpful responses!
Regarding the indoor humidity: I just measured it, and it’s around 65% during the day, even slightly higher at night. The shelf is placed directly against the exterior wall in the basement, where it can sometimes be a bit cooler than the rest of the house.
I have indeed noticed slight bulges in some areas.
I still have the following questions: Is it worth replacing the affected panels, or can intensive drying and treatment repair the damage? And what do you think about applying a sealant after mold removal?
By the way, it would be possible to reduce the basement humidity permanently with a dehumidifier, but I am concerned about the energy costs.
Dilen schrieb:
"With KALLAX … moisture then penetrates the particleboard, causing it to swell and allowing mold to develop on and beneath the surface coating."
