I am considering mounting an IKEA Kallax shelving unit on casters to make it easier to move around the room. However, I am concerned about whether this would affect the unit’s stability and if it might be more prone to tipping over when loaded.
My question is: Do Kallax units on casters tend to tip over more easily than those without? If so, what should I pay attention to (e.g., type of casters, weight, mounting method, floor surface)?
I mainly use the shelving unit to store books and some decorative items, so it is quite heavily loaded.
I would appreciate any tips, experiences, or technical advice. Thank you!
Keatondra9 May 2023 11:05Hello juchen,
I understand your concern, as the Kallax shelf from IKEA was not originally designed to be mobile on casters. The stability can indeed change when adding casters, especially if they are not lockable.
What you should consider is first the choice of casters: Lockable, wide casters provide more stability and prevent not only tipping but also unintended rolling. Additionally, it is important to distribute the weight as evenly and low as possible within the shelf—place heavy books in the lower compartments and lighter decorations on top.
The type of flooring also matters: Casters roll well on smooth, level floors like laminate or hardwood, while they roll worse on carpet, which can partly stabilize the unit.
If you load the shelf very high or even place heavy objects on top, the risk of tipping increases significantly. If tipping is a major concern, it is also worth securing the shelf to the wall, especially if there are children or uneven flooring.
I hope this helps!
I hope this helps!
Hello juchen,
I would like to provide a more detailed response, as the topic of Kallax units on casters is somewhat complex.
1. Risk of tipping due to casters: The Kallax shelf has a relatively low center of gravity from the factory, which ensures stability. When casters are installed, the height of the floor contact point increases, shifting the center of gravity upward – this increases the risk of tipping depending on the load.
2. Type of casters matters: Soft, large casters distribute weight better and roll more easily but tend to be less stable. Locking or brake casters reduce the risk of rolling away or tipping over.
3. Load distribution and center of gravity: Heavy items should always be stored at the bottom. This reduces the leverage effect that contributes to tipping. Ideally, avoid placing large, heavy, irregularly shaped items on top.
4. Installation: Casters should be securely attached – IKEA casters from the accessories are often easy to install but not designed for heavy loads. Sometimes it’s worth choosing casters from third-party suppliers that are rated for higher weights.
5. Floor surface: As Keatondra already mentioned, a smooth and hard floor is best suited. Uneven floors increase mobility and the risk of tipping.
In summary: Kallax units on casters tip over more frequently than without if the casters are inadequate, the load is uneven, and the shelf is heavily loaded. However, with the right casters, careful loading, and possibly additional wall anchoring, the risk can be well controlled.
Hope this helps!
Hope this helps!
Keatondra schrieb:
The stability can actually change when casters are installed, especially if they are not lockable.Agreed. Additionally, it should be mentioned that IKEA itself does not recommend casters for Kallax, due to the design. The shelving unit is not built for dynamic loads that can occur when moving it on casters.
Furthermore, the load capacity of the casters must be considered: inexpensive casters often have a low load rating, which can lead to deformation or easier tipping.
sinhau schrieb:
Choosing third-party casters designed for higher loads.That is an important point that is often overlooked.
Conclusion: If you do not want to install wall fixings, then definitely use high-quality, lockable casters with sufficient load capacity, place heavy items at the bottom, and keep in mind that a Kallax unit on casters inherently carries a somewhat increased risk of tipping.
sinhau schrieb:
Always store heavy items at the bottom. This reduces the leverage effect when tipping.Thank you for the detailed explanations. I understand the importance of the center of gravity, but sometimes the shelf ends up being loaded unevenly. I am therefore interested to know if you have any experience with how stable it really is on regular parquet floors, especially if you don’t use wall anchors and move the shelf around frequently?
CHENFAR schrieb:
that IKEA itself does not recommend casters for Kallax, which is due to the construction.That’s an interesting point I wasn’t aware of before. Should one rather opt for fixed furniture if stability is the top priority?
For me, casters would only be an option if I can move the shelf quickly and easily without having to worry about it tipping over or falling apart.
I’m curious if anyone uses the shelf like this in daily life and can share their personal experiences.
