Hello everyone, I am considering expanding my Ikea Hemnes shelving units and would like to know if this is generally straightforward. Specifically, I am interested in whether individual components – such as separate shelf sections or side panels – can simply be lined up or stacked without compromising stability or appearance. I have also heard of additional connectors but am unsure if these are officially provided by Ikea or if it is better to use independent solutions. Does anyone have practical experience or tips on how to extend Hemnes shelving systems effectively and safely? Thanks in advance!
To objectively assess the expandability of Hemnes shelving units, I recommend considering the following points:
- Ikea does not offer official extension sets for Hemnes beyond the usual side-by-side arrangement.
- The individual cabinet modules have specific connection points, but these are designed for certain load limits.
- For larger expansions, wall mounting should be planned to prevent sideways tipping.
- When making independent extensions without Ikea accessories, there is a risk that the load-bearing capacity may be compromised.
Overall, expansion is possible, but only to a limited extent and with appropriate caution regarding load distribution and stability.
Fitigu schrieb:
Ikea does not offer official extension sets for Hemnes beyond the usual side-by-side arrangement. That’s an important piece of information, thanks! So, you can’t just screw another unit to the side and use the side panels as a connector, right? Or would that risk damaging the structure? And what about wall mounting – is it enough to secure each individual unit, or should the entire extended shelving system be fastened as one?
In addition to the previous posts: Hemnes modules are primarily designed as individual furniture pieces. A lateral connection by directly attaching the side panels is not intended by the manufacturer and may negatively affect the stability of the shelves.
For a stable extension, the following is recommended:
- Use of additional connecting elements such as brackets or metal plates to securely join two modules.
- Securing each shelf module to the wall.
- Checking the maximum load capacity per module according to Ikea’s specifications.
Without these measures, loads may be distributed unevenly, which can lead to material weaknesses.
Thank you very much for the detailed response!
That is exactly my concern and the question of how easily this can be solved with my own ideas or materials. I will probably get additional brackets so that the extension isn’t simply resting without support. Of course, I will also secure the shelves individually to the wall. The only remaining question is whether anyone knows of alternative solutions that work particularly well? For example, certain connectors that Ikea does not supply?
emilemo schrieb:
I will probably get additional brackets so that the extension is not just resting on simple support. That’s a start, but have you checked how the additional connections affect the load capacity of the shelves? It’s pointless to connect only the side panels if the shelves and back panels become unstable afterward.
When extending, you should always consider the entire system: load-bearing capacity, material thickness, and connection points. Therefore, my recommendation is to avoid any self-built construction without detailed planning.
