ᐅ Who knows of affordable alternatives for shelves in the Kallax unit?
Created on: 3 Apr 2022 08:17
Kigovin
Kigovin
3 Apr 2022 08:17
I am planning to equip my IKEA Kallax shelves with additional shelves, but I do not want to buy the expensive original shelf boards. The standard boards are too costly for me, as I need to outfit several shelves accordingly. Therefore, my question is: Does anyone know of affordable yet sturdy alternatives for shelf boards suitable for Kallax units? It is especially important to me that the alternatives fit well into the existing support rails or are easy to install without requiring major modifications.
I would also appreciate tips on materials or sources. Thanks in advance!
LOGEMIN
3 Apr 2022 08:45
Hello Kigovin,
Regarding your question about affordable alternatives for Kallax shelves: A very common and reliable method is to have cut-to-size boards made from plywood or MDF at your local home improvement store. The standard width of Kallax shelves is 33 cm (13 inches), with a depth of 39 cm (15 inches) for the 4x4 units. It is important to accurately transfer the holes for the runner rails to ensure the shelf is stable once installed.
Here is a brief guide:
1. Measure the original shelf (width x depth).
2. Compare wood types: MDF boards are inexpensive and smooth, plywood is more durable but somewhat more expensive.
3. Have the boards cut at the home improvement store, paying attention to thickness (Kallax shelves are about 1.5 cm (0.6 inches) thick).
4. Mark the drill holes yourself or use a template copied from the original shelf.
Tip: Make sure the holes are drilled precisely, otherwise the shelf may stick or wobble. This way you can save a good amount compared to the original shelves and also try different materials.
If you need more details about screws, wall plugs, or mounting, just ask.
Dopoki
3 Apr 2022 09:12
I can only agree with LOGEMIN. MDF boards are an affordable, durable, and easy-to-work-with alternative. However, it is important that the boards have sufficient thickness to support the weight of items without sagging.
Additionally, various online retailers offer inexpensive chipboard or MDF cut-to-size panels that you can order in specified dimensions. Installation is the same as with the original, and the effort required is minimal.
You should also be careful with surface treatment. Painting or laminating protects the board from moisture and increases its lifespan.
glapu
3 Apr 2022 10:05
Make sure that the replacement shelves have exactly the same thickness and hole spacing as the original shelves. Otherwise, the guide rails will not fit.
Plywood from the hardware store, cut to Kallax dimensions, is affordable and sturdy.
andre3
3 Apr 2022 11:38
As an addition:
There are also so-called panels made of coated carpenter’s chipboard, which are covered with melamine resin. These are often cheaper than MDF but less resistant to moisture.
For interior areas without moisture exposure, they can be a suitable alternative. It is important to work precisely during installation, as melamine panels can easily chip if handled improperly.
If appearance is not a priority, many people also use simple plywood panels, which can be cut to size as desired.
Emery
3 Apr 2022 13:01
I recently found replacement shelves made of coated MDF at a large home improvement store, specifically designed for Kallax shelves. These were about 40% cheaper than the original shelves from IKEA. The fit is identical since they are cut specifically for this purpose.
Alternatively, you can use relatively thin OSB boards as shelves. They are sturdy and affordable, but the surface is less attractive and may require additional finishing depending on your needs.
