TAUHINRI4721 Mar 2015 19:37Hello everyone,
I recently bought a KALLAX shelving unit from IKEA and am currently thinking about the most stable way to set it up. The question I’m wondering about is: which is actually more stable – assembling the KALLAX shelf lying horizontally or standing vertically?
Specifically, I mean which option wobbles less, stands more securely, and can support heavier items better. Some say that using it vertically is more stable because it’s designed to carry the individual compartments perfectly. Others argue that the horizontal setup works better under heavier loads since the weight is distributed.
I’m interested in arguments from both mechanical and practical perspectives. Maybe there are also experiences regarding stability when the shelf is fixed to the wall or with shelves (boards) of different thicknesses.
How have you solved this? In your experience, which setup offers truly more stability?
Looking forward to your insights!
Basically, the KALLAX shelving unit should be used as intended by the manufacturer, which is vertically. This is because the design and material thickness are optimized for this orientation.
The vertical position ensures that the individual compartments can evenly bear the load.
Using it horizontally presents two issues: first, there is no stable side panel to absorb lateral forces, and second, the stresses are concentrated more on the joints, which can lead to material fatigue over time.
Wall mounting can improve stability in both cases, but the vertical position is still the safer option.
Oh, I also first tried my KALLAX horizontally and was really surprised at how good it looked! 🙂 But after a while, I noticed it became a bit unstable with heavier items. So I set it up vertically and screwed it securely to the wall – now it’s super stable!!!
It’s amazing how the shelf simply has more strength in the vertical position. Especially when you put in boxes or file folders, it feels much safer!
So, my recommendation: better to go vertical and, if possible, fix it to the wall, then it stands rock solid! 🙂
My experience with KALLAX is clear: the design primarily considers vertical loads. The wooden panels and joints used are optimized for vertical compression.
Connection plates also contribute to stability, which are missing or undersized in horizontal setups.
If someone wants to use it horizontally – for example as a tabletop or bench – I definitely recommend adding extra reinforcements, such as brackets or additional panels for stiffening.
Without such measures, stability would be significantly worse, especially under dynamic load.
To fully understand the stability of the KALLAX shelf unit, it is important to explain some technical aspects that determine its load-bearing capacity:
1. Material Thickness and Load Directions:
The KALLAX is made from medium-density fiberboard (MDF) with a laminated surface, optimized for vertical compressive loads. The edges are finished with ABS edging, but this does not provide additional stability against lateral forces.
2. Compartment Construction:
The compartments are designed to transfer weight from top to bottom. The central and side panels carry loads directly to the floor; this is especially important when supporting heavy books or equipment.
3. Horizontal Position – Weak Points:
When the shelf is placed horizontally, the load distribution and stress directions change: the support area becomes small, and the compressive load acts more on what was originally the side panel, which is thinner and less able to bear weight.
4. Wall Mounting:
Whether positioned horizontally or vertically, secure attachment to a wall greatly enhances stability by reducing tipping hazards and absorbing shear forces.
Summary:
Vertical placement is the technically sound and stable option. It can be used horizontally but only with additional reinforcements and careful attention to load limits.
4. Wall Mounting:
Summary:
I would like to share my practical experience:
Firstly, the vertical orientation is the standard setup for almost all IKEA shelves, which already indicates how the shelf was designed.
However, I have also used the KALLAX horizontally as a bench, with an additional wooden board placed on top to help distribute the load and stabilize the unit.
Without this reinforcement, I noticed that the shelf would bend slightly under pressure—especially when multiple people sat on it or heavy objects were placed on it.
Therefore, my advice is: if you use it horizontally, make sure to add an extra stiffening layer or support structure to protect the material and avoid stability issues.
What about you? Do you use cross braces or additional elements?
