ᐅ KALLAX panel leaking on the wall side – what could be the cause?
Created on: 9 Mar 2017 18:37
BefeklaHello everyone,
I have a KALLAX shelf from IKEA placed against a wall at home, and I’m facing an issue that I can’t quite explain: the side of the shelf against the wall is becoming damp, or the shelf itself seems to be absorbing moisture on the wall side. I couldn’t find any direct source of water, no obvious leaks or signs of wall dampness, but the shelf feels increasingly moist there.
My question is: what could cause the wall side of a KALLAX shelf to get wet? What factors might lead to the side against the wall becoming damp, even though there are no visible water damages? I want to avoid long-term damage to the material or mold growth.
I have considered whether it might be related to condensation or if humidity plays a role, but I lack a basic understanding.
I would appreciate any helpful insights or suggestions. Thanks in advance!
Hello Befekla,
First of all, it is indeed possible for a KALLAX shelf to become damp on the side against the wall if certain conditions are met. A common cause is condensation on cold exterior walls. If your shelf is placed directly against an uninsulated or poorly insulated exterior wall, the wall surface cools down, and warm, moist indoor air condenses on the wall or the shelf surface.
The moisture can be absorbed by the shelf material, usually particleboard or MDF, leading to a damp surface and possibly mold growth. Thermal bridges in the wall or insufficient air circulation worsen this problem.
What can you do?
1. Move the shelf about 5 cm (2 inches) away from the wall to allow air circulation.
2. Check if the wall is cold and damp (e.g., with a fingerprint test or a temperature measuring device).
3. Improve ventilation and consider using a dehumidifier.
If possible, having exterior wall insulation or masonry damp-proofing checked could also help in the long term.
I hope this helps you already! 🙂
Befekla schrieb:
"Problem: Shelf becomes damp on wall side without external water source"
What can you do?
edisondan9 Mar 2017 20:11In addition to what SARBLA1 has already described well, I would like to provide a few more precise pointers:
A KALLAX shelf unit is typically made from laminated wood-based materials, which can absorb moisture quite quickly. Dampness on the wall side is usually caused by a combination of the following factors:
- Poor air circulation: When the shelf is placed directly against a cold wall, the air behind it cannot circulate and cools down, causing moisture in the air to condense.
- Thermal bridge: Exterior walls without insulation result in cold surfaces that promote condensation.
- Increased indoor humidity: Higher humidity levels (e.g., from cooking, showering, or insufficient ventilation) increase the risk of condensation.
Diagnostic steps:
1. Measure the surface temperature of the affected wall compared to other walls.
2. Check the indoor air humidity (optimal range is between 40–60%).
3. Ensure the shelf is not placed directly against a wall that might have rising damp or capillary moisture.
Suggested solutions:
- Slightly move the shelf away from the wall (about 5cm (2 inches)).
- If possible, install a vapor barrier or foil behind the shelf.
- Improve air circulation by ventilating the room.
- Check the wall for moisture and carry out sealing if necessary.
If structural defects exist, these should be addressed as a priority because otherwise the problem will keep recurring.
Diagnostic steps:
Hello Befekla,
I would like to clarify what to pay attention to in such a case, especially when a KALLAX shelf becomes damp on the wall side, even though there seems to be no direct cause of water damage.
I recommend going through the following points systematically:
1. Check the wall type and insulation: Exterior walls without sufficient insulation are often cold and cause condensation.
2. Distance from the shelf: If the shelf is placed directly against the wall, air cannot circulate. This stagnant, cool air leads to condensation on both the wall and shelf surface.
3. Assess the indoor climate: If the relative humidity is frequently above 60%, the risk of condensation and moisture damage on cold surfaces increases.
4. Shelf material properties: KALLAX is usually made of particleboard with a melamine coating. This coating only provides limited protection against moisture absorption. The shelf material can absorb moisture and thus appear “wet.”
5. Identify thermal bridges: Cold spots on the wall promote condensation. Infrared measuring devices can help locate problem areas.
Tips for improvement:
- Move the shelf slightly away from the wall to allow air circulation.
- A thin vapor barrier (e.g., PE film) between the shelf and wall can reduce moisture transfer.
- Regular cross-ventilation helps reduce humidity in the room.
- If possible, insulate or seal the wall afterward.
This is truly the simplest and often most effective step! Without air circulation, moisture formation is almost unavoidable. I would also recommend regular ventilation, especially in winter.
I hope this helps you make great progress.
edisondan schrieb:
"Move the shelf slightly away from the wall (approx. 5 cm (2 inches))"
Hello Befekla!
That sounds really frustrating! But I think it’s great that you’re already thinking about it before the shelf gets completely damaged!
From my experience as an end user, I’d like to add something important: Sometimes the issue is simply that the wall behind the shelf is painted with a non-breathable paint, or even covered with wallpaper that doesn’t allow moisture to escape. This causes a kind of trapped heat and moisture right at the wall.
[quote=PRA64, post: i9u7h8, member:XXX]"Pull the shelf slightly away from the wall to allow air circulation."</quote]
I did exactly that, and it really helped because the air stopped being trapped. This significantly reduced the risk of mold.
My tip: Try moving the shelf a little bit away – even just a few centimeters – and maybe ventilate a bit; often that makes a big difference.
If you want, you can also check the moisture resistance of the material at IKEA – that helped me better understand how sensitive it can be.
Good luck and don’t let it get you down! 🙂
