I am planning to use a KALLAX shelving unit from Ikea in my workshop to store tools and materials. Since woodworking projects occasionally take place there, I am wondering how resistant the KALLAX surfaces are to wood dust. Wood dust can often settle into the material or get trapped in small pores, which can be problematic especially for veneered or lacquered surfaces.
Is it possible to simply wipe off wood dust with a damp cloth, or are there long-term damages? Is the material (MDF with melamine coating?) really suitable for a harsh workshop environment, or would you recommend a different material?
I am particularly interested in whether wood dust affects the KALLAX surface in any way, such as causing discoloration or other damage.
Thanks for your experience and opinions!
Hello gebufar,
For melamine surfaces, neutral cleaning agents are best. Avoid harsh cleaners containing solvents, bleach, or abrasives.
My advice:
- Simply mix a mild dish soap in warm water.
- Wipe with a soft, damp cloth.
- Avoid using too much water to prevent water stains on the edges.
If you have tougher dirt, a special plastic cleaner suitable for melamine can help.
Please do not use abrasive sponges or gentle scouring agents, as these can dull the smooth surface.
Best regards!
My advice:
Best regards!
Regarding dust protection: There are special thin protective films that adhere statically to plastic surfaces and keep dust away. An alternative is textile covers made of fine fabric, which can be washed regularly. When covering, just make sure that moisture is not trapped.
gebufar schrieb:
If anyone has tips for suitable dust protection coversAnything that blocks air circulation can cause moisture problems. If you cover something permanently, make sure there is good ventilation or leave it open in the evening.
Whether to use plastic sheeting or fabric depends mostly on handling. Plastic is more practical, while fabric is better for long-term use.
Have you planned anything for dust extraction? I would focus on that—less dust overall means less risk for your furniture.
