ᐅ Kallax door does not close completely – have you tried planing it down?
Created on: 16 Jul 2024 09:24
GAGIK
GAGIK
16 Jul 2024 09:24
Hello everyone, I recently got a Kallax shelf from IKEA and noticed that the door doesn’t close properly. It sticks on the right side and therefore doesn’t sit flush. I’m considering lightly planing the door because the veneer or the edge might slightly protrude. Has anyone experienced something similar? Is it enough to sand the door lightly, or do I possibly need to adjust the hinges? I’d prefer not to change too much on the shelf, but of course, the door should close cleanly without sticking. I’d appreciate hearing about your solutions!
koduga
16 Jul 2024 10:37
Hello GAGIK,
I completely understand your frustration because I had similar issues with my Kallax. It's really annoying when a piece of furniture that should be simple doesn’t work properly. In my case, it turned out that the hinges were slightly misaligned, so the door wasn’t properly adjusted. I spent quite a bit of time fine-tuning and even used sandpaper to fix it because the door was pressing too much on one corner.
GAGIK schrieb:
currently the door is sticking on the right side and doesn’t close flush
My advice: You can sand it down, but very carefully! Only where it actually sticks. And try adjusting all the hinges first – often it’s due to minor differences there. Good luck, it’ll work out!
Filippo
16 Jul 2024 13:12
Hello GAGIK,
to provide you with the most accurate solution, I need a few more details. Are the hinges installed on the inside, as used in Kallax? I would also like to know if the shelving unit is placed in a corner or if the wall might not be completely straight, as this can affect the door alignment.
In general: Kallax doors are made from MDF or particleboard with a melamine coating, which can only be modified slightly without affecting the appearance. If the door is sticking, it is usually due to incorrect hinge adjustment or slight warping of the door or frame.
My suggested procedure is as follows:
1. Check the hinge alignment – these can usually be adjusted horizontally, vertically, and in depth.
2. If this is not enough, you can carefully thin the edge of the door using fine sandpaper or a sanding block, checking frequently.
3. Important: work only on the edge that contacts the frame, and sand only as much as necessary – removing too much material can cause an uneven fit.
koduga schrieb:
try all possible hinge adjustments first
– this matches my experience. Most Kallax doors have limited play, so I would not consider sanding before adjusting the hinges. How exactly is the door positioned in the unit? Is it sitting straight, or might it tilt slightly outward or inward?
nolan
16 Jul 2024 15:04
Door sticking? Adjust the hinges first. If that doesn’t help, lightly sand the door edge, just a little. Try using simple sandpaper, 120 grit usually works well.
Joshbe
16 Jul 2024 18:29
Additional information: Kallax doors have standardized hinges with usually three adjustment options: height, lateral, and depth adjustment. First, check all these settings using a Phillips screwdriver.
If the door still sticks despite correct hinge positioning, it is usually due to tight edge fitting. When planing or sanding, pay special attention to the edge banding, as excessive sanding can damage it and ruin the surface finish.
I recommend the following approach:
- Use fine sandpaper (at least 150 grit)
- Sand very carefully only in the areas where the door sticks
- Repeatedly fit the door and test it in between sanding sessions
Because of the melamine coating, removing too much material can cause problems. In extreme cases, gently straightening the frame may also help, provided it is made of wood.
lyndon
17 Jul 2024 08:53
A brief note on the materials: Kallax doors are not solid wood but made of coated engineered wood, usually MDF with a melamine resin finish. This allows for sanding, but it must be done carefully as the coating can quickly chip.
Filippo schrieb:
Door... made of MDF or particle board with melamine coating, which can only be minimally modified
If there is a slight sticking issue, often sanding just a few millimeters off the edges is enough. Use 220-grit sandpaper, removing no more than 1-2 mm (less than 0.1 inches). It’s best to use a small sanding block to ensure an even sanding.
