ᐅ Kallax unit disassembled and reassembled multiple times after moving – any damage?
Created on: 5 Jan 2024 08:14
Elpubi
I have a specific question regarding the Kallax shelving unit from Ikea. After moving, I have now taken apart and reassembled my Kallax unit three times, each time to make it easier to handle during transport. I have noticed that some of the connectors and corner joints seem a bit loose or show minor signs of wear after repeated disassembly and assembly.
My question is: Can repeated disassembly and reassembly of the Kallax system cause damage, for example to the dowels or joints due to stress? Or is the furniture generally designed to withstand this without any issues?
How about its stability in particular when it is frequently transported and rebuilt? Are there any known weak points to watch out for?
I would really appreciate any experiences and opinions, especially from those who have moved used Kallax units multiple times. Thanks in advance!
PeoDaniel
6 Jan 2024 07:52
Elpubi schrieb:
I’m also interested in whether there are differences between the Kallax shelves, for example with the various sizes (2x2, 4x4, etc.) or between older and newer versions in terms of connection quality?
Definitely yes. Larger Kallax models like 4x4 or bigger naturally have more stress points. These are reinforced with additional connectors but are also more prone to movement with frequent assembly and disassembly.
The older versions are generally built a bit more robustly, as over the years Ikea has optimized materials and manufacturing processes, which sometimes leads to easier production at the expense of durability.
In addition, the surface finishes react differently to frequent assembly. A foil laminate can chip more easily at the edges, while painted finishes are usually more durable. Still, the rule applies: the more often it is taken apart and put back together, the more visible and noticeable minor wear and tear becomes.
nolan
6 Jan 2024 08:09
Size matters. Larger Kallax units are heavier, putting more leverage stress on the joints. When moving frequently, regularly check the connections.
pikin
6 Jan 2024 09:15
Weight plays a crucial role in the stress on the joints of furniture similar to the Kallax type. The 4x4 or larger variants experience higher forces acting on the dowels and panels.
Equally important is the manufacturing process: older Kallax shelves often use thicker wood panels, which increases rigidity and therefore stability. Newer versions frequently try to save weight and costs by using thinner materials, which can negatively affect durability.
Assembly and disassembly should therefore be carried out very carefully, especially with larger Kallax units.
flo-Theres
6 Jan 2024 13:18
One more note about the surface: Be careful with the edges if you disassemble and transport it frequently.
Use carpet underlay or protective film wrapped around the edges during transport; this helps prevent damage to the coating or paintwork. It reduces cosmetic damage caused by friction and impacts.
GiRoyce
7 Jan 2024 07:01
In summary:
- Multiple assemblies and disassemblies are possible, but connections deteriorate.
- Larger models experience greater stress and therefore require more frequent inspections.
- Age and material differences affect stability.
- In short: careful workmanship and protective measures are key.
Elpubi
7 Jan 2024 11:26
Many thanks for the diverse and detailed responses! I will definitely take to heart the advice about using additional metal brackets, glue, and gently removing the dowels.
In the future, I will better protect my Kallax during transport and handle it as carefully as possible to maintain its stability through multiple moves.
Thanks also for the clarification regarding the size differences.
If anyone with long-term experience or special tips on the subject comes by, I look forward to hearing from you 🙂
